Pentax DSLR DiscussionTalk about Pentax Digital SLR technique here, including the *ist D series, the K100D series, and the K10D, K20D, and K200D models.
first time I hear of inferior noise performance on the Super.
For one, the sdm and dust removal are the only diffs I know of, and secondly, if noise is more, it's probably just a software/noise reduction thing on camera. Either way, When I had my (fantastic) K100D, I saw no need for going to the super, though Im sure it's as great as the non-super.
__________________
Pentax K20d
Sigma DC EX 18-50 f2.8, Sigma DG 70-300 APO, Pentax F 28-80, Cosina 28mm f2.8, Pentax 18-55 DA II, Raynox DCR 250
If there was a change in JPG processing, it would be a software change only. Any changes would also have been included in software updates for the non-super. Maybe they were comparing a K100D ver 1.0 to a K100Ds with ver. 1.0. The non-super wouldn't have any updates, which would be included in the super ver 1.0. Who knows.
K100Ds only added SDM and dust removal, I do't think there were any other changes between those two...
Yeah that's what I thought, but the testers seemed to be very positive about an improved JPEG output.
I was surprised too, but the testers thought it was quite noticeable.
Yes, very likely. It seems not very probably that the sensor quality has dropped. Regarding software noise reduction: I really like Pentax's approach which doesn't aim at complete removal but tries to retain detail as much as possible. Although the noise figures aren't as good and the images do not look as clean, I prefer them over the smeared and sterile looking counterparts from a Nikon D40, for example.
The test magazine I quoted above once did a pretty pathetic comparison, which was mainly based on measured noise levels. Obviously the ranking that results from such an investigation has very limited value.
Yes, actually I'm really, really happy and more than over the moon with my K100D. The reason I created the thread was that I tried to learn whether a change to the K100D super would only be advantageous or whether it would also entail disadvantages. Not that I'm envisioning a change in the near future, but should an opportunity arise to trade in my non-super for a super, I wanted to be prepared for an informed decision.
While I don't believe that the dust removal will work wonders, having the option to use SDM lenses would be nice. But I think I'll survive very well without that option and believe it could be great fun to rather try out classic lenses. Anyhow, in my case the limiting factor w.r.t. my pictures is not in front of the camera body, but behind it.
Yes, that's very likely. But such software changes can make quite a difference (at least for pixel peepers).
I don't think so. At least the "changes list" for the latest v1.02 firmware version for the K100D doesn't mention an improved JPEG processing. The two firmware versions for the "super" and "non-super" versions are certainly not identical as the key sequence for accessing the "debug / service" menu works with the "non-super" version but not with the "super" version and obviously the new "super" features need to be supported.
While it would be nice for "non super" users to participate from improvements to the firmware of similar models, I can sort of understand why Pentax avoids the cost of actually doing this.
Thanks again for the responses. It'll be cool to get further (perhaps even insider) perspectives on the differences between "super" vs "non-super".
How could there possibly be any difference in high ISO noise when it's the same sensor with the same number of pixels? Certainly the jpeq quality could be different, and so could the noise reduction algorithm. But inherent sensor noise, no way. Shooting in raw will give the same jpeg quality with the same noise levels on either camera.
__________________
Dan
___
K20D, K100D Super, DA 16-45mm, DA 55-300mm, DA 18-250mm, Kalimar A 28mm f/2.8, FA 50mm f/1.4, D FA 100mm Macro, Raynox 250, Sigma 530 Super flash, BG-2 and Travor battery grips.
Perhaps they went for a lower quality selection of the sensor? Perhaps they changed the wiring between the sensor and the A/D converters? Perhaps some new (SDM) electronics interferes with the highly sensitive A/D conversion?
All this is just wild speculation and I don't actually think any of this is true, but in principle it would be possible that the testers measured slightly higher noise that doesn't come from a different JPEG conversion.
Can you confirm that the models are identical in other aspects?
How effective did you find the dust removal of the K100D super?
Aside from the SDM support, Dust Removal (DR) system (which does work), there is the support for high-capacity SDHC memory cards. The cameras are pretty similar otherwise. K100D Super is 10grams heavier.
And note that these are pretty much the same suppositions made regarding why the K200D might have better high ISO performance than the K10D despite having the same sensor. In tha case, the ADC is *known* to be different, but there may well be other changes too. Or it could be that the claims of K200D superiority are just wrong. The banding problems on the K10D seemed to affect some more than others, and aside from a problem caused specifically by the battery grip, I don't know that anyone ever got a complete handle on what went into those banding problems and how thy might have been alleviated on K200D or - is has been also been claimed - on later-model K10D's.
If you're ever going to be in Auckland, PM me first and we can do a direct side by side comparison (I have a super). And maybe then take some actual photos
Thanks for the invitation! That'll be very cool. 8-) I'd love to do a photo tour (taking pictures with company that is). Although it may take a while, sooner or later I'll surely visit Auckland again and it'll be great to meet you there.
