im curious, why would you want to? why not have the lens in in the first place? if it wasn't there, how would you have known the composition and focus was right?
That is a very odd lens design! I'm not sure, but you could put the camera in sensor cleaning mode, mount the lens, and turn the camera off and on again. But I am not sure if you will damage the mirror in the process. I'm not even sure how you would frame the shot if you did get the lens mounted?
Very bad. Mirror goes down when powered off after sensor cleaning.
Hence the comment of damaging the mirror. As I believe that you cannot go from sensor cleaning mode to shooting without turning off the camera. Correct me if I am wrong.
POP,
Other then using a non-retrofocus wide angle, This would be useful when shooting animals remotely. This way the mirror noise doesn't scare them away.
Dave
