Go Back PentaxForums.com > Pentax Cameras > Pentax DSLR Discussion > k20d or k10d - which has better dynamic range
Pentax DSLR Discussion Talk about Pentax Digital SLR modes, technique, operation, and problems here (K and *ist D series).
12-16-2008, 03:03 PM   #1
DXOmark.com gives k10d better dynamic range than k20D.
DPreview says k20d has better dynamic range.
Who is right?
And are they noticeably better than the k100d?
Michael Barkowski is offline
12-16-2008, 03:30 PM   #2
Gallery Photos: 28
Originally Posted by Michael Barkowski View Post
Who is right?
DxO is over confident in (arbitraily choosen) mathematical formulas. Unfortunately.
As a photographer, I cannot trust any rating scheme which gives aggregate ratings like:
K20D: 65.4/100 (ranks #16)
GX20: 68.7/100 (ranks #10!)
(based on RAW which doesn't differ from one model to the other).
On topic:
The way DxO defines DR is DEPENDENT on the pixel resolution (a 1 Pixel sensor would always win...). So, my advice here is to only compare cameras with identical #pixels or completly ignore the measure.
falconeye is offline
12-16-2008, 03:34 PM   #3
Sure it does... The K20D uses PEF and the GX20 uses DNG
Actually, I mean that sarcastically, but without reading the reviews or ratings, that is probably the reasoning as flawed as that may be (they probably don't even realize you can spit a DNG out of the Pentax camera)
emalvick is online now
12-16-2008, 03:36 PM   #4
Who is right?
John Sheehy and GordonBGood calculated the DR of the K10 as over and above almost all DSLR's at the time.
Unfortunately VPN pretty well killed the advantage. The large increase in DR was attributed to the 22bit ADC, so was the pattern noise
dpReview dynamic range measurements have always been suspect by many.
K10 also had a sever cutoff on the high end. Once you hit it it was toast. Very severe blowouts.
jeffkrol is offline
12-16-2008, 03:43 PM   #5
Just by my comparisons, which isn't scientific, I say my 20 out does my 10.
magnum1 is offline
12-16-2008, 03:56 PM   #6
You also have to factor in ISO. I've read reports the K20D has good DR until ISO400, then it decreases quickly as ISO goes up...
kenyee is offline
12-17-2008, 10:32 AM   #7
All, thanks for the reality check
12-18-2008, 02:05 AM   #8
That reminds me.... Is there any advantage to setting the Pentax to PEF as opposed to using the more standard Adobe DNG format?
Just curious...
pentaxmz is online now
12-18-2008, 02:09 AM   #9
Just curious...
Yes. PEF is losslessly compressed = you get more pictures on the card.
Erik is offline
12-18-2008, 09:28 AM   #10
That's strange. On the PC, it's the other way around. PEF is not compressed, and DNG is losslessly compressed. PEFs from my K100D are 8-10MB, DNGs made with Adobe DNG Converter are about half that size.
12-18-2008, 10:47 AM   #11
Gallery Photos: 15
Either file format is *capable* of being compressed. But the *camera* will only compress PEF, not DNG (and models prior to the K10D did not even compress the PEF). You can create a DNG file after the fact using the Pentax software or the free Adobe converter, which can produced a compressed DNG as output starting from either PEF or DNG.
I think a lot of people - myself included - shoot PEF simly to fit more images on the card. After importing to the computer, you can either chosoe to convert to DNG or not. The advantage of converting to DNG would be the support for embedded metadata - IPTC info and so forth - rather than requiring XMP sidecar files or whatever other scheme your image management software might employ to record information about your files. But you have to consider whether it's worth the extra time it takes to convert and/or the possibility that some information might be lsot in the translation (even though it isn't *supposed* to be). And some people have very strong feelings about which format is more likely to be readbale 20 years from now. Me, I don't pretend to know the future.
Marc Sabatella is offline
Dynamic Range of K20D and K200D cbaytan Pentax DSLR Discussion 8 05-22-2009 09:04 AM
Dynamic range 200% K20D knumbnutz Pentax DSLR Discussion 13 03-29-2009 04:53 AM
dynamic range K20D dafiryde Pentax DSLR Discussion 4 01-08-2009 10:51 AM
K20D dynamic range enlargement? infosyn Pentax News and Rumors 41 04-30-2008 04:35 PM
K20d Dynamic Range? Don Boyd Pentax DSLR Discussion 2 04-07-2008 05:07 AM
