Go Back PentaxForums.com > Pentax Cameras > Pentax DSLR Discussion > Only 14 continuous JPEGs on my K20D
Pentax DSLR Discussion Talk about Pentax Digital SLR modes, technique, operation, and problems here (K-7, K-x, K series, and *ist D series).
Translations: Chinese Czech Danish Dutch English Finnish French German Greek Hungarian Italian Japanese Korean Norwegian Polish Portuguese Russian Slovak Spanish Swedish
12-19-2008, 01:23 PM   #16
And also make sure the battery is full.
12-19-2008, 01:27 PM   #17
Quote Originally posted by nostatic Quote
have you tried burst mode?
I just did, and I only get about 5 seconds of burst mode.
12-19-2008, 01:34 PM   #18
Quote Originally posted by Peter Zack Quote
I am re-charging both batteries (original Pentax) as we speak. The camera has shown full on the batteries, but I'll let you know if of makes a difference.
I am sorry if my first post to this GREAT forum is a pain, but I am greatful for the help so far.
12-19-2008, 01:38 PM   #19
Quote Originally posted by netuser Quote
Unload all the pictures from the card. Format it and then try again.
I have done that. Still no joy.
12-19-2008, 02:02 PM   #20
It won't do 38 JPEG pictures if your shooting with the quality set at 4 stars. It will if set on 3 stars. That might be your problem.
12-19-2008, 02:33 PM   #21
Flyer you may have solved t. I just had a look at mine and realized it was set at 3 stars. It will do 38 frames that way without issue. At 4 stars. It slows down a lot and will only do 19-20 frames. At 2 stars I stopped at 50 and it was still shooting.
Since I shoot Raw + and only use the Jpegs a quick previews I had never checked the rating which is the default setting I think.
12-19-2008, 02:44 PM   #22
Flyer and Peter Zack,
I thought this might be the solution too. But at two stars, I am still getting only 18 frames before it goes to 1 frame per second.
12-19-2008, 05:03 PM   #23
What quality setting do you have set? The manual specifies up to 38 frames can be shot in one sequence at quality level ***. I've heard people say that **** jpegs are almost as big as RAW files, so if you're on that highest quality (least compression) **** setting, that could be the cause.
EDIT: oh! there's a page two. Now I look dumb!
12-19-2008, 05:55 PM   #24
Quote Originally posted by heliphoto Quote
No... not dumb. More like great minds think alike. However, it seems like I need a GENIUS mind to solve my problem!
Any takers?
12-19-2008, 06:34 PM   #25
What kind of SD card are you using? If your card is very slow (like a model dating from the dinosaur era), it might not clear the buffer fast enough to allow the camera to keep on going. It might also be a defective card. You might want to try another card. Just a wild guess.
12-19-2008, 09:28 PM   #26
m8o
Exactly... what card is it? My 2 Gig card allows for much faster writing than my 8 Gig card. Also realize, the K20D has about 47% (is it) more pixels to push than the K10D... I don't remember the site but there was a huge SD card speed comparo. Some budget cards are ridiculously slow. The camera buffer will fill-up if the card speed is too slow to keep-up with the write speed.
12-20-2008, 05:09 AM   #27
I have tried three different cards:
Transcend 8GB Class 6
PNY 4GB Class 6
Sandisk 8GB Class 2
I'll head out today and buy a Sandisk Extreme lll 4GB. I had assumed that the buffer in the camera was able to hold 38 JPEGs before it needed to record them to the card.
I'll let you all know how I make out.
Peter Zack, what card did you use on your test?
12-20-2008, 06:07 AM   #28
Problem Solved!!!
I reset the camera to initial settings in the setup menu and I now get 40 frames on my class 6 cards and 37 frames on my class 2 card @ 14.6MP JPEG ***. I also get 16 frames in RAW, even after re-applying all of my preferred settings.
I have no idea what changed. Is it possible that a reset is like rebooting a computer?
Thank you all for your input.
12-20-2008, 07:02 AM   #29
That's good to hear. I have no idea what the issue was but glad to hear it's cleared. Yes the camera does reboot like a computer and fix a number of issues. I just never thought that would fix this. I was begining to think it was a bad buffer memory.
The card was a basic run of the mill Sandisk SD 4 Gb (the blue ones that are nothing special). Cheap slow but a solid card. I tried a slower card to see if that was the issue.
12-20-2008, 10:29 AM   #30
I'm glad your problem is solved. I thought about a reset too, but I rejected it , thinking it was a buffer problem, so next time I have a problem (I've been lucky so far), I'll give this a try.
continuous shooting k20d jolee1990 Pentax Beginner's Corner Q&A 4 09-10-2009 09:30 PM
K20D and FA50 continuous-shoot exposure problem? defiant Pentax DSLR Discussion 6 04-22-2009 08:57 AM
K20d, still hotpixel issue with jpegs or something wrong with my camera? Karn Pentax DSLR Discussion 9 08-09-2008 03:33 PM
How to post unlimited JPEGs (e.g., K20D originals) falconeye Pentax DSLR Discussion 15 06-03-2008 08:50 AM
Improved Continuous AF Tracking of the K20D RiceHigh Pentax DSLR Discussion 41 03-19-2008 08:39 PM
