Originally Posted by Dice
I took some photos yesterday and upon uploading them to flickr noticed a regular square pattern in the foliage, bark most areas. I'm not sure if this is my fault or something else. I'm looking for some help.
Here is the link to the flickr page
Mt Diablo Snow - a set on Flickr
If you run the slide show I think it shows it pretty well.
kevin
Even thugh your link shows nothing here, I can say there are two kinks of moire effects.
First one is produced in camera, when certain patterns are pictured and the "cadence" of such patterns closely matches the cadence of the sensor's pixels. This WAS usual with 1 to 3 megapix cameras with very sharp glass, shooting things like fabrics, tight screens (mosquito nets) and such. This type of moire pattern is actually in the pictures and will not go away by resizing unless you are creating thumbnails, in which such pattern is so greatly reduced in resolution that it turns into a blob.
The other is produced in your computer screen, when the actual pattern pictured is showed at a certain resolution, that closely matched your screens resolution. This moire pattern goes away if picture is resized or by simply enlarging or reducing in screen. You can tell if this is your case when the moire pattern "changes" its appeareance when you enlarge or reduce picture in screen.
I believe this is your case. Such moire pattern may well be not showing on everyone's screen. You simply, by accident, resized your picture in which a photographed pattern closely matched your screen's resolution.
A simple test to discard this, is to actually print the picture (high quality) by lab or inkjet with photo paper. I am almost shure the moire pattern will not show on the print.
