Go Back PentaxForums.com > Pentax Cameras > Pentax DSLR Discussion > Pro Applications..Making 10.2 megapixels in to 30.6 mega pixels
Pentax DSLR Discussion Talk about Pentax DSLR modes, technique, operation, and problems here (K and *ist D series).
04-29-2007, 03:45 PM   #46
Ok, I'm trying this and my results are getting better with every detail you add. Many thanks, Ben!
If one layer is desaturated, should it be the bottom, middle, or top layer when blending?
Thanks again,
Will
wmmk is offline
04-29-2007, 03:50 PM   #47
Originally Posted by benjikan View Post
Thanks for reminding me. Please play with the "opacity" and "fill" sliders to garner the effect you are after. After that, I go in to "Shadow-Highlight" and compensate for the increase in contrast to bring out more of the shadow detail and reduce the highlights.
Ben
By the way, do you flatten before doing a shadow/highlights? Thanks again!
wmmk is offline
04-29-2007, 04:16 PM   #48
Gallery Photos: 171
Good Question
You can do that for each layer and save your file as a three layer 16 bit image or flatten. To benefit from the larger file, I guess you might "S&H" for each layer, which I often do.
benjikan is online now
04-29-2007, 04:19 PM   #49
Gallery Photos: 171
Honestly, I don't really consider it..
Thanks again,
Will
You know, I haven't really noticed. I also often have just one B&W layer and the other two, one being the original and the other duplicate in colour. Play around with it. The colour layer the more saturated it will be. Don't forget the "Fill & Opacity Sliders". Mine usually end up about 60-80 for each...
04-29-2007, 05:47 PM   #50
Gallery Photos: 6
I've used various permutations while experimenting with this method over the past few days. I know there must be something to it because someone who has no idea that I'm messing around with this has noticed a difference.
Comment on one of my recent photoblog posts in which the method was applied:
"I really like the effect you got on your shots the past few days Mike; what did you do?"
Mike Cash is offline
04-29-2007, 05:56 PM   #51
Gallery Photos: 171
Bravo...
I am pleased that you are finding this approach helpful in adding to the impact of your images.
Best Wishes
Ben
