Originally Posted by xjjohnno
Using spot metering Steve centre weighted.
Were you using spot or center weighted? Your post doesn't specify.
If you were using spot metering and not compensating each and every exposure to take the reflectivity of what was in the metering zone into account, your exposures would be completely whacked.
I still question the wisdom of putting spot metering onto a DSLR, but apparently I'm in a minority.
However, if you don't know what a spot meter does, and if you don't know how to use a spot meter, you are pretty much guaranteed to get bad exposures with spot metering.
