Go Back PentaxForums.com > Pentax Cameras > Pentax DSLR Discussion > K10D/K-7 viewfinders comparison
Pentax DSLR Discussion Talk about Pentax Digital SLR modes, technique, operation, and problems here (K and *ist D series).
05-27-2009, 08:22 PM   #1
Here is the difference between K10D and K-7 viewfinders. I took K-7 viewfinder picture at Pentax booth at Henry's show in Toronto with my Finepix F20 at identical focal length to what I did at home with my K10D, which should realistically represent apparent viewfinder sizes.
This is the confirmation of my initial side-by-side test at the first day of the show using Mike's K20D and K-7 where I have noticed that K-7 viewfinder appeared a bit larger. Here is what to expect:
Ivan Glisin is offline
05-27-2009, 09:16 PM   #2
Very nice. Thanks for posting this. The k10d/k20d had probably the best APS-C viewfinder of any camera brand, and it is nice to see confirmed the K-7 will be even larger.
PentaxPoke is offline
05-27-2009, 10:13 PM   #3
Ash
Gallery Photos: 100
That's a nice improvement, although the OME53 loupe makes an even better improvement!
Ash is online now
05-28-2009, 04:41 AM   #4
Just to confirm, this is how big the viewfinder itself appears to the eye, rather than the coverage of the viewfinder, right?
jfsavage is offline
05-28-2009, 08:36 PM   #5
Correct. This is the "visible" difference: by shooting through both viewfinders with the same camera at identical focal length positioned in the same way at the eyepiece it is possible to show the difference in the apparent sizes, which very closely approximates what our eye would see.
05-28-2009, 10:14 PM   #6
Nikon D300 viewfinder is still better. 100% coverage and 0.94× magnification.
Edvinas is offline
05-28-2009, 10:33 PM   #7
Gallery Photos: 23
Actually the D300 has a larger and brighter viewfinder
soccerjoe5 is offline
05-31-2009, 09:32 PM   #8
Gallery Photos: 4
This ain't really the place, but I put my K1000 to my eye a couple days ago and was amazed at how big and bright it was. I know it's apples and oranges, but you would think that they could tweak the pentaprism to give us a larger field of view on APS.
code4code5 is offline
06-01-2009, 04:36 AM   #9
Full Frame will give a bigger magnification - the Canon 5D has a great viewfinder. On the other hand the four thirds system is like looking through a key hole ;{
jfsavage is offline
06-01-2009, 05:32 AM   #10
You could, but it'd make the image darker.
pingflood is offline
06-01-2009, 07:56 AM   #11
Gallery Photos: 4
Theres so many problems with the four thirds system its hard to work out how olympus manage to sell a "profesional" DSLR and charge so much for all their lenses.
An olympus was my first DSLR and even then i knew something wasnt right.
Their marketing team must be legendary
IsaacEastgate is offline
06-01-2009, 08:09 AM   #12
Marketing team must be good enough to pull the wool over the eyes of the dpreview guys too, since they rate the Olympus DSLRs quite high.
I've shot a bit with an E-3 and it's an extremely well built camera, with very fast autofocus and some great lenses available. Sure, high ISO isn't great, but you can't have it all.
06-02-2009, 08:55 PM   #13
Gallery Photos: 23
I wonder how Olympus managed to do this on the E-3. It's got a big and bright VF and it's magnification is more than 1x.
06-02-2009, 11:34 PM   #14
I should have qualified that with "all else being equal". Changes to the pentaprism/mirror and focusing screen would definitely affect the output.. but in the end, you only have X amount of light coming in and if everything else remains the same spreading it out across a bigger area makes it dimmer.
06-04-2009, 08:11 AM   #15
I only ever looked at the lower end Olympus cameras, and they were 'keyhole viewfinders', which removed Olympus from my consideration immediately. How does the E-3 compare with the K20 - have they managed to make it as big and bright? If they have, then bigger viewfinders should be possible for APS-C cameras as well. One of the things I loved about the Canon 5D was the viewfinder.
jfsavage is offline
K-x vs K10D ISO comparison test photos rjm Pentax DSLR Discussion 12 11-18-2009 03:12 PM
fun *ist DS - K10D comparison SouthShoreRob Post your photos! 2 03-04-2008 06:35 PM
Interesting K10d K20d comparison PentaxPoke Pentax DSLR Discussion 24 03-04-2008 11:37 AM
comparison of pentax/canon viewfinders raz Pentax DSLR Discussion 2 06-03-2007 12:15 PM
Direct comparison *ist-D vs K10D sandpiper6 Pentax DSLR Discussion 4 12-14-2006 06:04 AM
