For all K7 user, maybe you can test this too.
I'm not 100% sure its a bug or not... but I need the heading to draw some attention.
ok ok .. I don't normally do this.
I find the JPEG picture mode got a weird bug (or you can call it a new feature!!!)
I cannot set independent values for sharpness and fine sharpness. Whenever I slide the setting, the other follows.
I just turned on my K20, and behold! I can set independent values for sharpness and fine sharpness!!
Do you think that's how the new K7 should work?
If you shoot raw.. obviously no need to worry about this. I only shoot raw for work, and jpeg for leisure, so this is quite important to me.
I suspect the fine sharpness setting introduce the "grains" we typically see in K7 output. See my sharpness comparison here:
Why these speckles at iso 100 in K-7 that wasn't there with the K10D
Mike
