Go Back PentaxForums.com > Pentax Cameras > Pentax DSLR Discussion > K7 AF lever?
Pentax DSLR Discussion Talk about Pentax Digital SLR modes, technique, operation, and problems here (K and *ist D series).
08-19-2009, 04:04 PM   #1
K7 AF lever?
Guys and Gals,
Does your AF lever 'click' into position on all three modes? MF, AF.C and AF.S?
Mine 'clicks' into MF and softly clicks into AF.S (the top one) but not AF.C. It annoys me... i have to actually look at it to be sure it is in the correct place.
mike
schmik is offline
08-19-2009, 05:11 PM   #2
Originally Posted by schmik View Post
Guys and Gals,
mike
Mine acts exactly like yours.
pcarfan is offline
08-19-2009, 06:31 PM   #3
Gallery Photos: 13
Ditto here. A little annoying, but not a biggie for me.
Arpe is offline
08-19-2009, 07:11 PM   #4
Yep, seems to be designed that way. A bit annoying to have no positive feedback as it changes settings. Thankfully, mine almost never leaves the AF.S position.
RBellavance is offline
08-19-2009, 07:25 PM   #5
Yes, judging by the appearance of the switch, you would expect it to 'click' into each position - but surprisingly it doesn't. Oh well, at least we all know that's normal.
Spock is offline
08-20-2009, 11:44 PM   #6
Which intrigues me as to why it wasn't made into a toggle/rotate switch like the RAW button. Less chance to fail, easier to seal, less moving parts, easier to put together.
wolfier is offline
08-20-2009, 11:48 PM   #7
Gallery Photos: 12
But you would not be able to see what it is set to.
quarc is offline
08-21-2009, 12:24 AM   #8
it can use the top LCD. how important it is to see the AF setting when the camera is turned OFF anyway?
wolfier is offline
08-21-2009, 01:03 AM   #9
I often do manual focus when the metering is not active. Manual focus can be done anytime on a dSLR as long as the lens cap is open.
For my style, anyway, its pretty important for me to confirm visually that I'm in MF mode before I proceed. On a DA-lens with Quick-Shift focus, you have no other way of knowing its set to AF if the metering is off.
Pressing on the shutter only to find that I'm in AF mode would spoil everything I had set up beforehand.
kittykat46 is offline
08-21-2009, 08:39 AM   #10
That I understand, but is there a disadvantage of keeping the camera ON? The battery drain is so insignificant it's negligible for most cases.
wolfier is offline
