Go Back PentaxForums.com > Pentax Cameras > Pentax DSLR Discussion > K-7 shake reduction problems?
Pentax DSLR Discussion Talk about Pentax Digital SLR modes, technique, operation, and problems here (K and *ist D series).
09-13-2009, 06:51 PM   #1
I was reviewing pictures taken on Saturday and noticed that many of them are not tack sharp. Many of them were looking like they have slight motion blur.
I have started experimenting and it seems that my K-7 SR works very inconsistently. Sometimes it works, sometimes it is not and even worse — it introduces motion blur.
100% crops from test pictures. All EXIF info should be there. Shutter speed was 1/180s, focal length 45mm, I was waiting until shake reduction indication was on.
Typical result with Shake reduction ON
Typical result with Shake Reduction Off
Any comments?
Edvinas is offline
09-13-2009, 07:15 PM   #2
Hi edvinas,
I shoot mostly long tele, and usually SR works to my advantage. I have found that it seems to work better if I'm more casual in my holding technique though. I've had very good success with my DS at 500mm, and 1/125, so I can be pretty good with my handholding technique, so I figured that I'd just be that much better with SR. I soon found out that I seem to be much better off if I just pretend that I'm shooting snaps with a big, heavy P&S.
If the results that you've shown shouldn't happen with the shutter speed/FL that you were shooting at. If the results were consistently like this, I'd try overiding the tendency to try to use good holding technique and see if that helps. I know it sounds wierd. . .
Scott
snostorm is online now
09-13-2009, 07:23 PM   #3
That's true, I have steady hand, usually I easily beat 1/focal lenght rule...
Anyway, I am worried because I did not experience anything like that with my K10D. SR was always on and I was not getting motion blur in high shutter speed situations
So, is it typical for K-7 SR system or simply my camera is faulty?
Edvinas is offline
09-13-2009, 07:36 PM   #4
Gallery Photos: 4
The EXIF says you're using a 45mm lens, but I don't know of a 45mm lens. Was it the 43mm Lim? Or, was it the 16-45mm @ 45mm?
The first thing I thought was that you had a manual lens on it and forgot to set the focal length (I do that all the time ) but if it's a DA lens, that wouldn't be a problem.
K-7 or otherwise, if you're getting worse results with the IS on than with IS off (shooting handheld), it definitely sounds like a problem that needs to get fixed.
Especially if you're getting blur at 1/180s with a 45mm focal length!
RawheaD is online now
09-13-2009, 07:48 PM   #5
It was DA 16-45mm @ 45mm
Edvinas is offline
09-13-2009, 07:54 PM   #6
Sounds like a fault with your camera unfortunately. Have you tried live view? That will keep shake reduction on and show you the effects immediately (going on my K20D here).
defiant is offline
09-13-2009, 10:25 PM   #7
i've heard about this a lot for fast shutter speeds. It is very unfortunate, especially with cameras without a dedicated SR switch. Please fix this, Pentax, sony/oly does not seem to have the same problem.
Eruditass is online now
09-13-2009, 10:51 PM   #8
Hi edvinas,
I never used to shut down SR for tripod use with anything before the K20 (K10, K100DS), but have found it necessary for the K20 and K-7. It sounds funny, but I think these models' SR systems are less forgiving of good handholding technique.
Easy enough to give it a try -- or hand the camera to a novice, and see how a similar test comes out in his/her hands. If the worst thing that happens is that you learn that maybe you only use SR for longer FLs, then I think I could live with that. . . but of course, YMMV
Scott
09-13-2009, 11:13 PM   #9
I've found that the K-7's SR works more effectively if I just hold the camera in a relaxed, natural manner, and not go out of my way to be still, if you know what I mean.
The camera shake-prevention posture I learnt from my film days isn't the best way to work with an SR camera, that's what I've seen.
However, I really haven't experienced a hand-held case where the SR makes the camera shake worse. If you can rule out lens BF/FF focus issues, actual subject movement, accidental movement of the camera, etc. you'd probably want to return the unit to be checked.
kittykat46 is offline
09-14-2009, 12:10 AM   #10
I too have seen worse results with SR than without some times. I'm a good handheld shooter that beast the 1/f rule.
Haven't tried to experiment with the casual approach. I will try and see what happens.
kjellhar is offline
09-14-2009, 01:34 AM   #11
I sort of having similar issues in the old firmware, but haven't experience it so far with the latest revision 1.01.xxxxx09.
Have you tried latest firmware?
mcjm78 is offline
09-14-2009, 01:44 AM   #12
I have the latest firmware, but I must admit that I don't remember which firmware I had when I last saw the problem. I delete those images, and also I have started to keep SR off most of the time.
kjellhar is offline
09-14-2009, 01:57 AM   #13
Last hour I've taken about 100 pictures with K-7 + DA 16-45mm with various shutter speeds and here's what I've noticed:
  • 1/180s seems like worst shutter speed for SR, slower and faster shutter does not produce such blur.
  • SR blur isn't consistent. There can be five perfectly sharp pictures and then something happens and SR blurs a few pictures.
  • In slow shutter sutuations when I need to get 2-3 additional stops SR works. Not 100%, but works. It looks really weird when SR manages to get tack sharp picture at 1/10 sec (45mm focal length) however blurs picture taken at 1/180 sec.
Anyway, from now on I will keep SR turned off and will turn it on only when I really need it.
Edvinas is offline
09-14-2009, 02:01 AM   #14
Not yet. Waiting for battery to charge fully.
Edvinas is offline
09-14-2009, 02:59 AM   #15
Gallery Photos: 155
Interesting that 1/180 sec happens to be the speed for flash. Just thinking out loud here but I wonder if there is a connection.
Damn Brit is offline
Shake reduction julianactive Pentax SLR Lens Discussion 2 05-06-2009 05:13 PM
shake reduction oatman911 Pentax DSLR Discussion 17 03-07-2009 04:38 AM
Thank you Shake Reduction! tcdk Post your photos! 4 09-03-2008 10:29 AM
Shake Reduction dvdman45 Pentax DSLR Discussion 8 05-07-2008 09:24 PM
More Shake Reduction = >IQ tswill2 Post Processing, Printing, Software, and Darkroom 2 11-28-2006 08:15 PM
