I have both the K10D and the KM (K2000) cameras. There is no shutter release button on either camera that I know of. You need to buy the Pentax electronic shutter release unit...about $ 30 Cdn.
I use it for both my K10D and KM...works well.
Yes, I agree that remote works well.... but as far as I know, it does not offer the ability to activate bulb remotely. That's the functionality I am looking for.
I'm confused about the terminology, and i'd like to do night exposures longer than 30 sec., e.g. bulb mode.
I found this electronic remote control switch on ebay from a Hong Kong vendor:
It uses a 2.5mm jack connection and the description talks about bulb functions. The description also says that it single shutter, as well as periodic shutter actuations over a period of time up to 99 hours, etc. It says the electronic switch works with the K10/20 and the K100/200.
So won't this work for me in controlling bulb functions remotely (i.e comes iwth 3 feet of cord roughly)
Any clarity appreciated :-)
Those cords are indeed for the earphone type jack on the K10/20 and will not work on the K-X.
You'll need an infrared remote to operate the K-X.
I have the Pentax one which is very small, but it's nice to use on my K10.
I believe the K-7 has a new mode in which the first click opens the shutter
and the second click closes it again, so you can use it instead of a cable remote with lock. I assume the K-X has this same feature.
Note that other infrared remotes can also operate your camera.
You can buy dedicated ebay ones, but you might also try the buttons from your TV or an universal remote. I read somewhere that this works for some types.
that is awesome - if it has this, I am very happy.
If you have to push the shutter release to open and close the shutter, does this mean that you are likely to introduce camera shake?
Or do you mean this function is available in the remote control?
I assume it means either (remote control effectively is the same as pushing the shutter release button).
Holding it down is possible but not practical for 10 minute + exposures. And actually, the ebay remote I have doesn't work with holding it down, but should work with clicking once to open and once to close.
If I was not clear, I indeed meant using the IR remote control.
It's on page 86 of the K-7 manual, function 17:
------------------8<-------------------------------
While using the remote control in
p (Bulb) mode, sets whether to start
exposure with a press and stop it with
another press of the release button on
the remote control, or to keep the shutter
open as long as the release button on
the remote control is kept pressed.
------------------8<--------------------------------
It would be nice if the X-P manual got online...
Yeah, I wouldn't assume that would be an included feature on the K-x though--they do like to keep a gap between their consumer and prosumer bodies, and sometimes they get rid of the tiniest little things!
The mode you are referring to was called T mode on the older Pentax leaf shutter or view cameras. In T mode you could have the shutter stay open until you depressed the shutter button a second time. This mode is not available on any of our dslrs. Because the K-x is designed as an entry level dslr it will not accommodate using a cable switch release like our CS-205.
If you are in need of further assistance, please respond to this email or call our technical support center at 800-877-0155.
Sincerely,
xxxxxxxxxxxxxxxxxxxxx
Pentax Imaging Technical Support
Your Email:
Is it possible to use bulb mode with long exposures without having to hold down the shutter release?
I noticed there is no jack so a cable release with a timer is not
possible. I know I can hold down an IR remote or the shutter on the
camera, but I have heard of an option on other Pentax cameras to have the first shutter press start bulb mode, and the second one stop it. Is this possible on the K-x or are long shutters supposed to be difficult on the K-x?
I responded with how the K-7 has this custom option. I can only hope that the k-x has this option!
