Go Back PentaxForums.com > Pentax Cameras > Pentax DSLR Discussion > K-x high ISO pics from Halloween outing
Pentax DSLR Discussion Talk about Pentax Digital SLR modes, technique, operation, and problems here (K and *ist D series).
11-03-2009, 03:03 AM   #31
Originally Posted by ogl View Post
The main problem of K-x is COLOUR. IMO.
I've played with RAW from K-x. It seems to me - K-x has strange yellow, red and green.
To correct the colour of each photo in convertor is rather lazy for me.
Yellow has green cast, red is with raspberry pink cast, green is a bit acid green.
The colour are not well-balanced and I can say it's rather pops colours.
With higher ISO - more acid. The jpeg from Raw and in-camera jpeg are rather similiar.
No way to set good colours with WB level in RAW-converter. Need to work under all colours separately.
As for JPEG - either pale, or too "acid".
Of course, there are a lof of pops colour-lovers...
What Kind of mushroom do you use?
flyer is offline
11-03-2009, 03:34 AM   #32
ogl
Gallery Photos: 12
I used PEF, DNG and JPEG from K-x.
ogl is offline
11-03-2009, 03:35 AM   #33
ogl
Gallery Photos: 12
Originally Posted by rawr View Post
Nothing at all is wrong with the K-x colours. Why do you even bother posting such foolishness. Get ahold of one and see for yourself.
Compare with K-7 or with cameras with CCD from Pentax.
Can you?
http://www.flickr.com/photos/1189995...7622477827457/
http://pentax.photoble.net/?s_cat01=...=&act=DSP&L=en
have a look at the photos at the first page of this thread.
ogl is offline
11-03-2009, 05:40 AM   #34
"Don't feed the troll(s)"
simico is offline
11-03-2009, 06:05 AM   #35
I give you another perspective.
1. Most of the people who visit photo related forums like this one are photographers and understand enough the importance of color. Because this is one of the most important aspect.
2. Most of the people are intelligent enough. They are not Einstein but have basic level of intelligence.
3. How many people you see complaining about color of k-x. I think you probably are the only one.
put all three facts together and here is conclusion - its not the camera its you.
zxaar is offline
11-03-2009, 08:32 AM   #36
There have been color, hue and saturation settings in the Pentax menu since the *istD. The new custom image menus are even better! if you don't like saturated colors, tone them up or down as needed. Choose "natural" that makes things pretty bland if you like that.
I happen to use the "bright" option with the saturation and contrast sliders bumped up a notch or two.
Here is a photo at 100 ISO, just to show how nice the colors are from a K-x.
skid2964 is offline
11-03-2009, 09:28 AM   #37
ogl
Gallery Photos: 12
[/IMG]
What happened with skin tones of faces?
ogl is offline
11-03-2009, 09:29 AM   #38
ogl
Gallery Photos: 12
Do you have eyes and good calibrated IPS monitor?
ogl is offline
11-03-2009, 09:31 AM   #39
ogl
Gallery Photos: 12
Open your eyes and try to see real red, yellow and green. Don't you really see that red is with pink (raspberry) cast, yellow has green cast and green is unreal green?
Skintones are out of my mind. Are we from Mars? K-x's colours are some surreal.
ogl is offline
11-03-2009, 10:19 AM   #40
ogl has got a point. skin tones doesn't look real at all or balanced. the saturation/color adjustment is quite tricky since the 3 faces display different strong color casts. unless of course the subjects are wearing make-up, are they?
Pentaxor is online now
11-03-2009, 10:31 AM   #41
My wife is wearing makeup, my daughters are not.
As noted above, I use "bright" custom image with saturation and contrast bumped up. I was mainly trying to show how rich the colors can be. If there are any flaws, it is my fault and not the fault of the camera.
I may have had the flash unit a tad too close to them as well. I held it to my left at arms length. I get better tones when I back up and use a longer focal length.
skid2964 is offline
11-03-2009, 10:47 AM   #42
thanks for confirming that. btw, you should had boosted up your ISO there instead. I think that would be more suited on that occasion. besides, what's the use of buying the k-x if you're not going to use it's ISO potential. I'd suggest that you set aside your flash for now and let the k-x's ISO do it's job !!!
11-03-2009, 11:07 AM   #43
That was like the 5th or 6th photo I had ever taken with it. I had also installed new flouresent bulbs in the dining room lamp that threw me off.
Yes, I agree, I need to at least use 200 ISO as a base and possibly 400 to 800. With this camera, you can truly get away with it.
skid2964 is offline
11-03-2009, 02:04 PM   #44
Gallery Photos: 15
Can you post one of the pictures you shot of a standardized color reference chart under high quality controlled lighting, so we can view the results on our own calibrated monitors using our own favorite RAW processing software to see this effect you refer to?
Or is it perhaps possible whatever effect your are seeing is just the way the scene actually was, or the way the color of the light actually was, or is just what your own RAW processing software and monitor happens to be showing you?
Marc Sabatella is offline
11-03-2009, 02:09 PM   #45
Gallery Photos: 15
No, it's just Halloween. What on earth makes you think those are *not* the actual colors of those costumes and that makeup under the color of the particular fluorescent bulbs used? And of course, as the EXIF made clear even before he mentioned this explicitly, this picture was taken in Bright mode with saturation, contrast, and sharpness all turned up as well. Any camera that produced "normal" looking colors under those conditions would be severely defective!
People Belated Halloween pics from Salem, MA wasim_altaf Post your photos! 1 11-12-2009 05:03 AM
High ISO bad? MoparFreak69 Pentax DSLR Discussion 10 07-21-2009 09:58 AM
K-7 high ISO vs K20D high ISO supa007 Pentax DSLR Discussion 25 07-10-2009 07:00 AM
Halloween Pics poochie99 Post your photos! 11 11-03-2008 12:10 PM
Night photography with K10D - High ISO short exposure VS Low ISO long exposure pw-pix Pentax DSLR Discussion 10 02-03-2008 01:37 AM
