Go Back PentaxForums.com > Pentax Cameras > Pentax DSLR Discussion > K-x high ISO pics from Halloween outing
Pentax DSLR Discussion Talk about Pentax Digital SLR modes, technique, operation, and problems here (K and *ist D series).
11-04-2009, 11:48 AM   #61
ogl
Gallery Photos: 12
I've asked at Russian penta-club about green cast in yellow.
They see the same...
ogl is online now
11-04-2009, 11:51 AM   #62
Gallery Photos: 15
Originally Posted by ogl View Post
I think you don't understand what I mean...
Have a look at yellow... Do you really see no any green cast?
Absolutely impossible to say unless you are looking at the same bag in the same light to compare with. Otherwise, how would you know the actual colors of that bag in that light aren't exactly what you see here?
FWIW, I loaded it into ACDSee, and the "yellow" pixels read around 190/200/2. Again, without knowing the actual color of the dye used and that of the light used, it's *impossible* to know if this is correct or not. But even if it weren't, so what - all that means is AWB kicked in to remove some of the color cast from the light, just as it it should. Try shooting a color reference chart after doing a manual WB setting if you want to make any claims whatsoever abut color. Otherwise, you're just guessing.
Similarly for people claiming to be able to tell just by looking at a picture that the skin tones are 'waaay" off - unless you've got those very people sitting right next to you in that same light, you basically have no idea if it's accurate or not. Considering the makeup and the settings used (contrast, saturation, and sharpness all cranked up), that picture looks (on *my* calibated monitor) completely within the range of what should be expected. Now, if those girls are actually, say, of Arab descent, I'd agree the skin tones appear off. But if, for example, they are of northern European descent, it looks about right for the settings chosen.
Marc Sabatella is offline
11-04-2009, 11:52 AM   #63
Gallery Photos: 15
Then ask one of them to post a shot made under controlled lighting of a standard color reference chart - since that's the only way one can make claims like that, obviously, they must have such shots they could share...
11-04-2009, 12:00 PM   #64
Yup, we just plain ole' white folk with photographically inadequate makeup.. LOL
skid2964 is offline
11-04-2009, 01:42 PM   #65
talking about picture i posted.
why green color disappear when I desaturate all other colors??? If it is there should show up.
zxaar is offline
11-04-2009, 01:43 PM   #66
Originally Posted by GerryL View Post
I just love it how people can't get satisfied..if it's not one thing, it's the other.
its not only that people see one file and make concrete conclusion based on it.
zxaar is offline
11-04-2009, 01:46 PM   #67
here is one more picture of that wrapper, from a shapping web page.
give you some idea how that pack could look like.
zxaar is offline
11-04-2009, 03:50 PM   #68
okey i asked someone else to have a look at and he did some cleaning.
green-yellows.jpg by Bear_Music - DPChallenge
in way you were right that there is some green cast. But the snacks never look like pure yellow so the top is though now pure, not correct representation of scene. The bottom is still close to actual scene.
zxaar is offline
11-04-2009, 07:57 PM   #69
I'm wondering if you used AWB on this one. the K-7's AWB does display a bit of a bluish hue under tungsten lighting on a reflective purple glossy subject. so this might be a mishit on the part of the k-x's AWB. although I didn't say that the k-x's AWB isn't very good.
Pentaxor is offline
11-04-2009, 11:07 PM   #70
Originally Posted by Pentaxor View Post
I'm wondering if you used AWB on this one. the K-7's AWB does display a bit of a bluish hue under tungsten lighting with a reflective purple glossy subject. so this might be a mishit on the part of the k-x's AWB. although I didn't say that the k-x's AWB isn't very good.
yes it was auto white balance. When i reach home i will post exif too.
I tried to keep as much as auto as possible and with touching anything from my side.
zxaar is offline
11-05-2009, 09:09 AM   #71
Gallery Photos: 15
True, had both pictures been shot in the same light and with the same WB. Since neither of those were likely the case, it doesn't really help.
11-05-2009, 09:09 PM   #72
agree with ogl that the pictures appear to have weird colors. yellow hue on skin tones
but i think it should be adjustable with the settings on the camera
if its using the same sensor as d90, i used to change the mode to neutral -1 sat
Nikon Imaging | PICTURE CONTROL SYSTEM
bunegg is offline
11-05-2009, 09:34 PM   #73
Gallery Photos: 6
It's a different sensor than that in the D90, and Nikon's picture controls are likely to be at least subtly, if not significantly different than Pentax's picture controls. No dice.
er1kksen is offline
11-05-2009, 10:15 PM   #74
Try shooting with Natural instead of Bright
Eruditass is online now
11-05-2009, 10:33 PM   #75
Originally Posted by skid2964 View Post
Yes, I agree, I need to at least use 200 ISO as a base and possibly 400 to 800. With this camera, you can truly get away with it.
I'm pretty positive you'll be able to 'get away' with more than that!
I'm betting that the K-X will match the D90's high-ISO output. This is ISO 1000 (f/2.2) from
the D90, no NR applied in PP:
Crop:
Here's ISO 2000, f/2, again, no NR:
(these were both odd lighting, the second an extremely yellow tungsten cast -
I left the color exactly as the eye saw.)
So yes, put your flash away and use that wonderful little camera to it's full potential!
(love the colorful wife-kids shot, BTW)
jsherman999 is offline
People Belated Halloween pics from Salem, MA wasim_altaf Post your photos! 1 11-12-2009 05:03 AM
High ISO bad? MoparFreak69 Pentax DSLR Discussion 10 07-21-2009 09:58 AM
K-7 high ISO vs K20D high ISO supa007 Pentax DSLR Discussion 25 07-10-2009 07:00 AM
Halloween Pics poochie99 Post your photos! 11 11-03-2008 12:10 PM
Night photography with K10D - High ISO short exposure VS Low ISO long exposure pw-pix Pentax DSLR Discussion 10 02-03-2008 01:37 AM
