Go Back PentaxForums.com > Pentax Cameras > Pentax DSLR Discussion > Need Confirmation k7/wireless/SR
Pentax DSLR Discussion Talk about Pentax Digital SLR modes, technique, operation, and problems here (K and *ist D series).
11-03-2009, 03:05 PM   #1
Hi thinking of coming back to the Pentax fold after a 1.5 year absence (k10d and all gear were stolen). Spent that time with Nikon and really grew to love wireless flash on my d300. So here is the deal. I use a lot of wireless fill flash with 2 sigma 530's. Am I correct in thinking that even if I am using a sigma in the hotshoe to fire a wireless unit that I will lose SR?
rkboid is offline
11-03-2009, 04:31 PM   #2
Why would a flash unit effect shake reduction? Is that your question?
enoeske is offline
11-03-2009, 06:10 PM   #3
My question is:
Would I be able to use SR if I have a sigma 530 wirelessly controling a second sigma 530
rkboid is offline
11-03-2009, 06:24 PM   #4
Yes, you can use shake reduction regardless of what flash you have attached to the camera.
enoeske is offline
11-03-2009, 06:45 PM   #5
So SR is only disabled if the built in flash is used?
rkboid is offline
11-03-2009, 07:08 PM   #6
Ole
Gallery Photos: 96
SR is disabled if the internal flash is used to control another flash wirelessly.
SR is not affected in the scenario you describe.
Ole is offline
11-03-2009, 07:09 PM   #7
pbo
I think you got it wrong a bit. SR is disabled when a wireless remote is used to trigger the camera.
The reason behind that is because, well, when you're using a remote to trigger a camera, you probably put it onto a tripod or something steady, and SR would not be beneficial. Smart, eh?
Also, same happens if you use 2 sec or 12 sec drive timer.
Edit+what Ole said
pbo is offline
11-03-2009, 07:42 PM   #8
No, he's right about that part...at least on the K10D and K20D, if you use the popup flash as the master, SR was disabled because they figured the flash pulse would "freeze" motion, and I think they needed the CPU cycles.
Not sure if Pentax fixed that "feature" in the K7/Kx...
kenyee is offline
11-03-2009, 07:46 PM   #9
Thanks for clearing that up for me. I know my K10d could not do wireless flash and SR.
rkboid is offline
11-03-2009, 08:17 PM   #10
pbo
Oops, sorry, misunderstanding...
With built-in flash as primary, SR works, with wireless - nope. The little hand doesn't appear....
pbo is offline
11-03-2009, 08:20 PM   #11
If its any help, when I use wireless mode on the flash, the preflash triggers my lumopro lp120 and thus it doesn't lit up during the intended exposure period. SR might not work with wireless set up anyway. So, to me, wireless mode is useless.
However, if I fire a regular flash from my K20d at -2ev, it will trigger the flash wirelessly and at the correct timing. And SR will work that way.
enoeske is offline
11-04-2009, 04:33 PM   #12
Gallery Photos: 13
That's just dumb isn't it? Why disable SR when internal flash is master, but not a flash on the hotshoe?
Arpe is offline
11-06-2009, 12:26 AM   #13
From page 134 of the Pentax K-7 user manual:
[Shake Reduction] is automatically set to (Off) and cannot be selected in the following situations.
- Wireless mode with an external flash
(and a bunch of other situations, but that's the only one relevant to this discussion).
knoxploration is offline
K7 SR confirmation ken Pentax DSLR Discussion 10 07-13-2009 09:53 PM
Focus confirmation light bc_the_path Pentax DSLR Discussion 4 03-19-2008 07:28 PM
AF360FGZ Flash Confirmation wiseman Camera and Studio Accessories 3 02-23-2008 02:46 PM
New: Registration Field Confirmation Adam PentaxForums.com News 0 03-16-2007 01:31 PM
Focus Confirmation - Viewfinder Timbuctoo Pentax SLR Lens Discussion 10 02-21-2007 09:42 PM
