I am going to have several rolls of Velvia 50 and Provia 400 developed and I am wondering if I should have them mounted or not. The scanner I have available has both a carousel for slides and a roll feeder, so that's not an issue. Is there a downside to storing negatives in the canister as opposed to mounted and in a box?
Negs/slides in canister are a bit more prone to suffer under handling as they are taken out and returned to the canister, but other than that, it is up to your personal preference.
__________________
Albert in the Rockies http://www.flickr.com/photos/albert_berry/
SF-1, MZ-S, K10D + D-BG2 grip
M 100/4 Macro, M 400/5.6, A 70-210/4, FA 28-80, FA 24-90, DA 12-24/4, DA* 16-50/2.8, DA* 50-135/2.8, A 1.4X-S TC, AF 1.7X TC
Manfrotto 055B tripod + 0168 ball head, Benbo Trekker tripod, Velbon UP-43 Monopod
advantages of mounting:
*usable in projectors
*ease of marking, as titrisol said
*ease of handling
advantages of unmounted:
*storage size- strips of 5 in negative sleeves takes up a whole lot less space than fully mounted slides in a clear sheet. I've got 6 binders full of mounted slides, but I havn't filled up one binder yet with unmounted.
__________________
K10D, ZX-L; DA 14 f/2.8, DA 18-55, DA 50-200, FA 20-35 f/4, FA 50 f/1.4, K 200 f/2.5; Sigma 28-80 f/3.5-5.6, Quantaray (Sigma) 100-300 f/4.5-6.7 Diamond Bar X Photography
Whatever you do, DON'T keep uncut film in the cannister! I have dozens of rolls of 35mm b/w film my father shot in the 30's stored thus, and the film has a really nasty curl. As a previous post said, damage is likely taking the film out of the cannister; if you roll it up tightly to insert it the roll will expand to fit the cannister, making it hard to remove. Lengthwise scratches are almost inevitable.
I'd concur with mounting in plastic, or you could keep it in strips of 6 or 7 frames in the various transparent ring binder pages.
