Couple of springs broken and most likely merged with the rest of the mechanism so now the advance is stuck too.
One possible issue is:
When the shutter is released, the spill remains lowered... this might be due to:
a. Either a damaged wind-up shaft spring or to wind-up shaft spring slipping from the wind-up shaft, with the consequence that the idling gear does not back up properly; or
b. The bezel of the top idling gear is not properly positioned...
Other causes:
The bounce stopper lever does not slip off the bounce stopper.
The pin adjust plate stud is broken and sandwiched between the teeth of the gear.
The shutter curtain, especially the ribbon of the 1st curtain, is torn and coiled around the 1st curtain wind shafts.
Seriously Gooshin, probably not a hack you can do.
Contact Erik at Pentaxs.com
woof!
__________________
Seaain Gray
An rud a líonas an tsúil líonann sé an croí. ~ Irish Proverb.
("What fills the eye fills the heart.")
Believe me...this is not something you want to do. A camera shutter is a little like a mechanical watch, but much more complicated! Lots of little parts. It takes special tools to get to where you can even see the shutter mechanism. (The most obvious screws are not the right screws...I have been there...I know...)
Having said the cautions, there are several good books available at the library that detail the basic techniques, the tools, and what solvents/lubricants are appropriate. There are also places online where you can order supplies and tools.
There are things about the K1000 manual that are helpful as well. A lot of narrative here, and not all that much difference. Some to be sure. (Also password "Pentax")
Now you've done it. I looked at the pdf manuals and now have the sudden urge to disassemble my brother's and my Dad's K1000s. It's, it's, like an OBSESSION!! Must...fight...urge...must...not...harm...cameras. ..
(I have the tools and I know how to use them...sort of...)
I'm with you Gooshin. Your manhood has been questioned. Go for it. Take pictures. Post them here. The "Wendy B" thread will eventually wind down. We need some new entertainment. A tip of the hat to those who are providing the pistol and ammunition. I'll just stay in the peanut gallery. Even there a ricochet could get me.
P.S.: In the highly unlikely event you should have to bow to the inevitable (send it to Eric) he has plenty of spare parts. Not to worry. He is a nice guy. When I spoke with him yesterday about the Super Tak 35/2.0 I had started to disassemble and fix myself, he said not to worry, that he'd seen worse. My lens is packed and ready to go in today's mail.
__________________
Bill
That is a 1959 Cushman Eagle in my Avatar
Super Takumar 28/3.5, 35/2.0, 35/3.5, 50/1.4, 105/2.8, 135/3.5, 200/4.0
Pentax K1000, Pentax K100D Super
I am also a Site Supporter
