I have the Pentax ME Super, I am not very familiar with film cameras - I was snapping away with it and it worked fine, but then all of a sudden the mirror was locked up. It's not physically jammed as I can put it back down with my finger, but it pops back up after.
Thanks for chiming in - sadly I don't think it's the batteries, I have about 100 of those types of batteries from eBay. I insert them as the manual says and I see LED lights in the viewfinder. I think the camera has juice ...
Any other ideas?
Thanks,
Craig
Originally Posted by lurchlarson
I have an me super. This has happened to me before. Your batteries are probably dead.
Any other ideas?
Thanks,
Craig
I think the light seals might be breaking down and getting sticky. It happened to my old ME Super and I've never taken the inititive to get it fixed.
Thanks, after trying everything unsuccessfully, I will just send it to that guy - or abandon it to eBay if his rates make my heart stop.
have fun
Craig
Craig,
Dont sell it as it seems like an easy fix.
It looks like the rubber seal (where the mirror slaps) has aged over time and has turned a bit gooey / sticky. I had a similar issue and bought the below pre-cut seal kit from Jon Goodman (ebay id : interslice)
1. Bang the bottom into your other hand
2. Take the lens off; manually move the aperture stopdown lever
3. Remove the bottom plate; the largest lever underneath has probably not completed its run. Poke at it with a screwdriver.
4. Remove film; push down on shutter curtain gently.
5. Send to Eric.
In that order Only progress if the previous step doesn't work.
Inside the mirror box, on the left (shutter release) side, there is the aperture stop-down lever or some such thing. It goes up and down. Use a fingernail or such and see if you can pull it down. The mirror might drop as it comes down. If this happens, the mirror comes down and stays down, I bet this means that something in the main mechanism is gummed up or needs overhauling.
Well, this is based on an MX.
Eric Henderson is very good. And very reasonable prices. I bet he does ME Supers in his sleep by this point.
Currently I own 4 ME Supers. 2 are completely dead beyond resurrection and 1 I raised from the dead and the last one I've got it for $20 and is in good condition.
This tells 2 stories. ME Supers are getting old and they were not made to last - need services. Secondly, they are plentiful and dirt cheap - if one dies get another.
Anyway, the one I raised from the dead had exactly the same symptom of yours. Although the symptom is same the cause maybe different but this is how I did.
What I found was that the mechanical gear on the bottom of the camera has jammed. I opened the bottom plate and poked with small screwdriver here and there and got it de-tangled (sorry I am not a camera reparier but I opened another camera and checked how it should be). I cleaned and put some oil on the moving parts and bingo! now it works like a charm.
