Originally Posted by netuser
... I finally bought 2 original pentax adapters.
My theory, as well, until I actually danced the M42 on my K100D.
Later, I found the best solution for me is to use one adapter (Pentax brand) on the body and screw the M42 into it each time. Once that's complete, I am forced into my check list:
- Focus: Lever change from AF to M
- Focus: Reset Af button to shutter in C Menu (makes it easy to see focus signal as you manual focus)
- Mode: Dial Manual
- etc... etc.
Once done, when I unscrew the M42 and remove the adapter ring, I'm reminded to reverse the check list so I can return to the dazzling 21st century world of AF and beyond.
The M42 experience has a delightful learning curve that requires planning.
There are many inspirational examples on this forum. They make doing the M42 look deceptively easy. Granted, you can learn a lot from the producers of these images, but you will never be able to fully grasp their world, or their eye for what works.
Instead, may I suggest that you work toward setting you own standards and developing your own eye. A good first step down this trail may be to expand your lens choices to include at least one really good Limited lens (DA 40 Ltd, DA 35 Ltd, or such). Adding a Limited to your palette will help you establish a standard of excellence that can be built on as you learn to do the M42. Blending these experiences will get you to M42 success faster and make it a ton more fun.
Go for it and enjoy... my 2 cents...
