The Pentax ES was the world's first 35mm SLR with a fully electronic shutter system. When set on automatic, the ES has a stepless shutter. The Pentax memory device computes and delivers an infinite number of exposures between 8 and 1/1000 second - automatically. If 1/555 second will give you the right exposure, that is what will be programmed.
The Pentax ES utilizes the last generation screw-mount Super-Multi-Coated Takumar and SMC lenses. In addition to the legendary flare control and color fidelity that has made these lenses so popular, the S-M-C/ SMC lenses are designed to allow open aperture metering on the ES, ES II and Spotmatic F. The viewfinder remains bright under all conditions, making focusing easy. In the event that earlier lenses without the open-aperture metering coupling, the ES provides stop-down metering with the familiar switch near the lens mount. In any case, the meter is activated by partially depressing the shutter release button. These features make the ES less than one-quarter inch taller and only six ounces heavier than the Spotmatic F.
The standard color for the ES was black, which was a departure for previous Pentax M42 bodies where black was a special order. With both the ES and ES II, chrome was the special order version. The ES name on the face of the body replaced Electro Spotmatic on the earlier model released only in Japan and had improved circuitry. The size of the circuits did not allow room for a self timer in the ES.
Price when New
7186 - camera with 50mm f/1.4 $360
7187 - camera with 55mm f/1.8 $320
7188 - camera body only $290
Asahi Pentax ES |
Also marketed as Honeywell Pentax ES | Year introduced 1972 | Year discontinued 1973 | Mount M42 |
Automatic aperture stop down Yes | Metering Open aperture, centerweight | Meter range EV 1 to 18 | ISO range 20 to 1600 |
DX ISO range No DX coding | Exposure modes Av, Manual, B | Exposure compensation 1/2x, 2x and 4x | Exposure memory lock No |
Shutter speeds (auto) 8s - 1/1000s (stepless) | Shutter speeds (manual) B, 1/60 (X), 1/125, 1/150, 1/500, 1/1000s | Shutter speeds (mechanical) B, 1/60 (X), 1/125, 1/150, 1/500, 1/1000s | Self timer No |
Mirror lock-up No | Auto bracketing No | Multiple exposures Yes | Winder Ratchet type rapid wind lever. 10° pre-advance and 160° advance angle |
Flash hot shoe Yes | Built-in flash No | TTL/P-TTL flash No | Flash sync speed FP and X terminals - 1/60s |
Flash exposure comp Not applicable | Viewfinder 0.89x (with 50mm lens), 93% coverage | Viewfinder type Pentaprism finder with Fresnel lens + microprism | Diopter correction No |
Exchangeable screen No | Depth of field preview Yes | Image size 24 x 36 mm | Battery 6V, Eveready #544 |
Battery grip/pack No | Size (W x H x D) 143 x 98 x 50mm (without lens) | Weight 678g | |
