Show Printable Version 14 Likes Search this Thread
05-26-2011, 08:33 AM   #16
QuoteOriginally posted by chicagonature Quote
I'm in Pentax's Professional Service program and I asked the rep about the claim that the backs can be converted. The answer is:
NO.
This should put an end to the discussion and speculation on this topic.
What would you expect them to say? First, Pentax would not want to take the liability of saying it is possible. Second, they would not want to do it.
05-26-2011, 09:15 AM   #17
chicagonature, can you try and obtain the exact reasons why a conversion isn't possible? If the rep is a technical one who knows his stuff then this should be no problem. If it was a sales rep then he may be simply repeating what the company line is as others have said.
We have at least three users here who have done the conversion successfully so it can be done. The question that remains is whether the conversion may have long term detrimental affects to the insert or affect the focus or even the neg spacing. It would seem from the users that they have seen no adverse effects on focus or neg spacing and I cannot think of what part of the insert might suffer from longer term damage or excess wear and tear from the conversion but the rep should be able to point to this straight away.
Pity he seems to have thought that a one word answer of NO was sufficient. Whatever you can do to get reasons as to why it is not possible or advisable to convert with reasons will, I am sure, be greatly appreciated by all here
Thanks
asahijock
05-26-2011, 10:24 PM   #18
chicagonature's Avatar
The rep was talking about the details for a couple of minutes and it all became a blur. He seemed to know a lot about it and his final answer of "No" was fine with me. I just sent an email to get the reasons in writing, so we'll see. Don't expect an answer from me, though. I just thought I'd help you out because I know someone on the inside and ended up getting involved in something that I'm truthfully not that invested in. Personally, I'll just buy 120 inserts. It's not like they cost very much. I just thought that an answer from the manufacturer's expert would be good enough. I didn't think there'd be a conspiracy theory. Grassy knoll?
05-27-2011, 06:20 AM   #19
Thanks for the response and initiating an e-mail to obtain reasons. The responses I am sure weren't an attack on you, the messenger, who was only offering what you percieved to be a helpful and authoritative answer from an expert which as you will have gathered is contradicted by some users' experience at conversion.
By the way the evidence seems to point to 120 inserts being much more expensive than 220 on both sides of the Atlantic. If a conversion is easy and safe then I am all for we P645 users saving money.
If the difference was a only few pounds or dollars I don't suppose many of us would be interested except on a sheer engineering curiosity basis.
asahijock
05-27-2011, 04:17 PM   #20
Hi Asahijock,
Here's an email answer from my rep from Pentax today:
Our shop never offered any such “conversion” and always indicated that the appropriate film holder must be used to match the film length. (If “users” are making their own conversions, we’re not aware what they are or what detrimental effects would result).
I suppose you're still on your own.
Good luck!
05-27-2011, 04:37 PM   #21
Nesster's Avatar
As I detailed before, the film length logic is taken care of by a simple mod.
Since then, I've learned some about film flatness - and how it may be compensated for by pressure plates and film channels. Although there doesn't seem to be a difference, there may be in the physical characteristics of the two inserts, i.e. a fraction of a mm may be difficult to notice, but may make a diff in sharpness.
Obviously, the film plane itself isn't different.
And at any rate, why speculate? If you have a 220 insert, try it, and report back! What's to lose?
05-28-2011, 09:34 AM   #22
Thanks chicagonature for the Pentax quote. It mentions "our shop" This might be a shop as in a technical shop but it might be a shop as in a retail outlet. Certainly the quote suggests to me that this is not an answer from a technical expert/ camera engineer in a workshop. It still fails to give the kind of explanation I'd expect to get from an expert who gets faced with a "why not?" question.
Pity. If it is from the technical dept of Pentax itself then it undermines its credibility. Pity again.
Thanks again for trying. That's all you can do.
asahijock
05-29-2011, 05:46 PM   #23
QuoteOriginally posted by Nesster Quote
You are right, a comparison is needed. I can see no difference - and actually, do not expect any, as changing the middle part's direction actually does fool the 645 in thinking a 220 is a 120 - but if there's a difference in pressure, it should be obvious from a controlled comparison. Alas, I am about to move, which means my screen cezanne scanner has been stored away since January, likely to last to August, but when I'm back to normal I will certainly try. Frankly, the Pentax rep's comment is clearly non-informative, but there may still be an issue and we should find out
06-05-2011, 11:44 AM   #24
grhazelton's Avatar
220 insert to 120 conversion
I sent this out a while ago in reply to another query.
It is very easy to convert the 220 inserts to use 120 film. All it takes is a jeweller's phillips head screwdriver and a few seconds. Don't lose the little screw! Here're instructions, courtesy of another member:
"- mikebob -
I am and experimental physicist - I had to try .... and ... it works !!!
In the second link you have provided is a detailed description, but let me put my version here (I checked it twice!):
So - when one takes out the back and looks between the latches that can be flipped out to load/remove the film spools - there is a little black plastic rectangular of size about 12 x 4 mm. On one of the long sides it has a small tooth. This little "thing" is attached by a small screw. One of these screws is slightly obscured by the steel teeth that holds the film insert attached to the camera. When I have bought the camera with the 220 magazine, the teeth was pointing towards the back of the camera (away from film plane) and was easy to overlook.
So - to find out how this should work I used 2 films to figure out (one would have been enough though)
1) with the "thing" in its original position (teeth pointing away from the film plane) I loaded one 120 film in the back and shot 20 exposures until the film went completely through the camera. Then the camera did a short winding attempt and showed "E" on the display, which I guess stands for Error.
2) Unscrewing the 2 small screws I turned the plastic "thing" such that the teeth was pointing towards the film plane. Loaded another film and shot exactly 16 frames. After that the camera wounds the rest of the film onto the reel and showed "End" on the display.
So - it seems that with the teeth pointing towards the film the camera (or towards the shutter when the magazine is mounted on the camera) expects 120 film. What remains to be checked is simply to shoot a film or two in this settings and see that everything is OK. I would guess everything will be fine
I do not expect a problem with the film pressure plate is this has a lot of space to move (much more than the one in my Roilleiflex T)
... now all of you will run to get those cheap 220 inserts ..."
Note: My 220 inserts have only one screw holding the "tooth," perhaps there was a running change. Nevertheless Mikebob's instruction worked perfectly. I've run several rolls of 120 through the "converted" insert and I can see no problems.
Of course you'll have to remember that you've made the conversion!
06-06-2011, 08:51 PM   #25
dugrant153's Avatar
I made a post on this, but it was probably on another forum
Just some visuals to help you out. Visuals help me a lot.
05-09-2018, 02:24 PM - 2 Likes   #26
Ok, I know it's an old thread, but it keeps being linked to when there is a discussion about using 220 inserts with 120 film.
I have both inserts and they are, in fact, different! Somehow it's not immediately obvious even when you look at them side by side, but 220 pressure plate has different thickness to accommodate for the lack of backing paper on 220 film. Although it may have no noticeable effect on the IQ, it has other implications to it. If you mod a 220 insert as outlined above and run a 120 roll through it you will immediately notice that the motor sounds different compared to using 120 film in 120 insert. This is because using 120 film in 220 insert puts more strain on the camera motor. This may wear the motor down faster, break it altogether or harm the camera in some other way we don't and can't anticipate.
This claim is supported by Eric, whom I contacted some time ago to seek his expert opinion on the matter:
The 220 film hold is made a bit different to hold the film tight to the format opening so it isn't loose. So when you put the two layer (120) film on a 220 holder it will put pressure on the motor to pull it through. So don't do it.
So yeah, don't do it.
That said, you can probably use a 220 insert in a pinch, but please understand, that you will likely be actively participating in your 645's untimely demise this way. Whether running down a perfectly good camera is worth the price difference between 120 and 220 inserts is up to you, but my personal opinion is it's not.
I'll post photos showing the difference between the inserts later.
05-22-2018, 02:06 PM   #27
QuoteOriginally posted by lightproof Quote
Photos would be welcome. I have just looked again at stocks in the two main U.K. dealers who sell inserts and neither have any inserts. Reverting to e-bay, nearly all such inserts now come from Japan. There was one from a U.K. photographic dealer and it was an insert converted from 220 with the claim that it was a perfectly safe conversion. So it would appear that even camera dealers are unaware of the dangers as quoted by Eric.
The final point I'd make is that there are almost no 220 films left. Based on Eric's quote such inserts should have almost no sales and soon should be virtually scrap and yet there are plenty for sale.
Finally as this thread is several years old, can I ask that those who have converted such as George Hazelton and others, please give us their experience of what if any problems they have since experienced with the camera's motor in the ensuing years that have now passed.
Thanks
asahijock
05-27-2018, 09:19 AM   #28
Ok, so I promised the photos showing the difference between 120 and 220 inserts. Here we go.
The 120 film insert is on the left, while 220 film insert is on the right.
Notice the difference in the pressure plates: the 220 plate is made thicker to compensate for the absence of backing paper on 220 film. The central dotted part on 220 plate is thicker than the 120 plate, while the plain "lips" on the sides (there is another one on the far end, but it's OOF) are the exact same thickness as the entire 120 pressure plate.
05-27-2018, 09:46 AM   #29
Thanks for the pics, lightproof. There clearly is a lip that can be seen on the 220 and as you say there is a corresponding lip at the other end, whereas the 120 has no lip. What remains to be discovered from "converters' experiences is how much of a strain this places on the motor. As far as I know 220 film is no longer produced and while I have heard that some can be purchased in Japan, it has disappeared from other markets. It is impossible to tell what the e-bay sales for 220 inserts are like but there are a lot of them about and they are a lot cheaper than 120 inserts. I'd imagine a lot of buyers buy them thinking that they can safely convert to 120 but buyers are storing up motor problems in the long run according to Eric.
I wonder if Eric has actual known examples of motor problems which stem from inserts that have been converted?
Thanks
asahijock
05-27-2018, 01:25 PM   #30
QuoteOriginally posted by asahijock Quote
You can get some fresh 220 Velvia/Provia from Japan or ebay while supplies last. It's probably from the last batch Fuji made in 2017 before discontinuing it. As of 2018, 220 film is not manufactured by anyone.
You can use a 220 film insert to shoot 35mm by using some 3D printed spool adapters. But while feasible with 6x6, 6x7 and 6x9 cameras, it's pretty much pointless on Pentax 645 as you will get a weird 41.5x24mm (roughly 7:4 ratio) frame that is only marginally wider than the standard 36x24 one. And you will have to hold the camera vertically to get horizontal shot. It could probably be fun, especially if you have Pentax 67 lenses, but using a P645→K (or any other mount) adapter will probably be much more effective.
So yeah, other than that, a 220 insert can only be used for parts to repair a broken 120 one, but that's probably it. Until someone starts making 220 film again.
645n, camera, film, magazine, medium format, pentax, pentax 645n
[Pentax 645N] Film insert/back 120 veraikon Pentax Medium Format 2 03-26-2010 01:59 AM
Tri-x (320) being discontinued in 120/220 Clicker Digital Processing, Software, and Printing 2 02-27-2010 09:33 PM
Recommendation for scanner for 35mm and MF with 120/220 hinman Digital Processing, Software, and Printing 26 02-12-2010 12:24 PM
Best 120/220 film for scanning DigitalSlide Pentax Medium Format 21 07-14-2009 08:53 AM
All times are GMT -7. The time now is 03:41 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
