Go Back PentaxForums.com > Pentax Cameras > Pentax Medium Format: 645, 6x7, 645D > Pentax 645N Brain Dead?
Pentax Medium Format: 645, 6x7, 645D Use this forum to discuss all aspects of the Pentax medium format systems.
09-26-2009, 11:15 AM   #1
I’m posting this in a number of Pentax/MF fora in the hope of finding a simple solution to my problem. I apologize if you encounter this elsewhere.
I received a used Pentax 654N with a 75mm FA645 f2.8 lens yesterday that isn’t working. I’ve photographed with 35mms for over 30 years, and with Pentaxs (Pentaxes, Pentaxia, ?) since the mid 80s, so I know my way around cameras. I’m pretty sure this one is busted, but it’s my first 645, or MF for that matter, so I’m hoping someone here with experience with the camera can point out something simple I’m missing.
The symptoms are:
1) With new batteries, it will not auto focus or advance a roll of film.
2) The top LCD is functional (ISO can be changed), but the Viewfinder Display only displays ‘1000 F—‘ regardless of aperture or shutter speed settings on the camera.
3) With the lens set to AF or MF, and the battery holder (with batteries) freshly inserted, when the shutter release is fully pressed, there is a ‘click’ from the front of the camera (I suspect it is the shutter trying to release) and the Viewfinder Display turns off and will not come back on until after the battery holder has been removed and replaced. With the lens set to AF, MF, or the lens removed, the Viewfinder Display illuminates when the shutter release is pressed half way, and goes off several seconds later.
I bought it from a well-known east coast (USA) camera retailer. I’ve emailed their support department and got the auto-reply “Our support center is currently closed in observance of the Yom Kippur Holiday, please try emailing again on September 29th”. I will try them again Tuesday, but am hoping to take some test shots this weekend.
Thanks in advance for any help you can lend.
*** Figured it out ***
So, I fiddled with it, and pressed the Mid-roll Wind-up Button a few times and heard a ‘click’. I put the batteries back in, turned it on, and it made a whirring sound as though it was trying to rewind the film (which wasn’t there). I tried putting a roll of film in, pressed the shutter release, and ERR showed up on the LCD. Dooooh! I pulled the film holder out, pressed the Mid-roll Wind-up Button again, and heard a click, put it back in, turned the power back on, pressed the shutter release and it rewound the film (I suppose I put it in backwards). I pulled the film out, put the empty back on, and it did the same as before, no AF, no shutter release. I tried to load another roll of film, and now IT WORKS! The AF works, the viewfinder display indicates the correct settings, and it takes pictures! Yes, a new old camera with quirks.
iCrop is offline
10-12-2009, 06:40 PM   #2
I think you put the film in backwards the first time.
Don't worry, I did too!
guidoanselmi is offline
Pentax 645N vs. 67 netrex Pentax Medium Format: 645, 6x7, 645D 37 09-26-2009 05:18 PM
Brain Disease? Rupert General Talk 5 08-12-2009 01:17 PM
pentax 645n flash alanc Camera and Studio Accessories 4 03-06-2008 10:05 AM
Problems with 540FGZ (or with the brain) honopik Camera and Studio Accessories 9 10-18-2007 01:28 PM
