Go Back PentaxForums.com > Pentax Cameras > Pentax Medium Format: 645, 6x7, 645D > MF scan, processing & film recommendations
Pentax Medium Format: 645, 6x7, 645D Use this forum to discuss all aspects of the Pentax medium format systems.
10-21-2009, 09:40 AM   #1
I recently picked up a Mamiya 645 1000S w/ 45/2.8 with the intent of re-visiting earlier days of B&W landscapes just for the fun of it. With about 25 years experience in 35mm B&W processing, I expect I'll end up processing film myself but it's been a while since I used film and some of the choices are different than I was familiar with.
With the ultimate goals of: a) just messin' about with MF gear and b) perhaps a few digitally printed 8x10 wall-hangers, I'd appreciate comments on today's films, processing, and scanning.
1. What's with the Kodak C-41 B&W film? I was expecting to use the old standbys like Panatomic and Plus-X which I see are still available, but . . . Fugi or Ilford perhaps?
2. Any suggestions for today's chemicals for day-light tank processing? Diafine? D-76?
3. Can I reasonably expect scans from something like the Epson 4490 to produce acceptable digital prints for non-commercial use? It will also be used to convert a bunch of older 35mm slides.
4. Any Mail Order processing suggestions for expediency until I get back in the saddle and as a QA comparison with my own work?
5. If I was to order slightly larger lab prints from my own negs, would the Epson-to-CD scans suffice or would it be necessary to send negs for lab scans.
Absolute top quality isn't the issue for recommendations here as I'll make my own decisions about the cost/effort/fun ratio after I have some results to compare. I'm just lookin' for some middle of the road, baseline suggestions to go along with my web research.
Thanks, H2
pacerr is offline
10-21-2009, 10:02 AM   #2
1) the Kodak (and Ilford) C-41 film is OK, only don't expect it to behave like real B&W when it comes to latitude etc. I've used these quite a bit over time... in 120 size you gain the expense of finding a minilab to develop it, and/or you have to send out. No cost advantage vs. color film (which you can then convert to b&w yourself in photoshop).
The old standbys are still good - Ilford and Fuji and Foma make some really nice films also. There's a bit of a split between traditional formulations and the newer T-MAX types - these modern films behave a bit differently than the traditional ones. I currently have a brick of Ilford Delta 100 I'm working through (it was cheap, and I like it enough)... The one film I don't get along with is TMAX 400 - the emulsion seems like it loves to suck in dust that is near impossible for me to get off the film.
2. I've used T-max developer, D-76, and Ilfosol 3, basically semi randomly. All produce good results. Rodinal looks to be in fashion with many; for me the simpler mixes work plenty fine.
3. I use the 4490, and it works well enough. Sometimes, depending on negative, there may be scanner noise evident. But for non critical 'enlargements' viewed at a rational distance (i.e. not pixel peeped close up) the 4490 should suffice for what you describe. I've made fine 19 inch wide prints from a 1500pix wide 35mm scan... and you can easily generate 5000pix wide files with the 4490, without half trying, with 120 film.
4. I've tried the mailers B&H sells - the results were ok, I felt the overall experience was over priced. I've also left the film at a local camera store - who's got someone locally willing to do B&W development - with better results.
5. see above. You can of course try & see. How large are you looking to print?
Nesster is offline
10-21-2009, 01:41 PM   #3
Thanks, Nesster
I'm leaning toward staying with something I was accustomed to for a while: Plus-X and D-76 for the time being simply as a point of departure.
A good assessment of the Epson 4490 for my purposes.
I may try a roll of the C-41 B&W in 35mm just to see what's different.
H2
pacerr is offline
10-21-2009, 09:05 PM   #4
Gallery Photos: 21
Ultimately you need to rediscover your own film/developer combination. There are lots of opinions on the subject. I'll tell you what and why I use what I do and you can even see some results in my uploaded pictures.
You have cubic and tabular grain films. Plus-X would be the cubic. The tabular scan well and are one reason for the rise in the use of Rodinal which can be pretty grainy with some films. Never use Rodinal on 320TXP, period.
I like one-shot developers with very, very long shelf life. Hence I use PMK Pyro and Rodinal a lot. Staining/tanning developers like PMK work best on old-school emulsion. I don't like messing around with developers that get exhausted with use. You only get one shot at the negative. Why bother with extending development times on solutions that weaken or age in the bottle. But that is a personal thing.
And for film there are still lots of choices. Panatomic-X died years ago. I still have two, 100-foot rolls of 135 in the freezer of it 8-) One film I find interesting is Fuji 100 Acros. That film is very fine grain like many with good tones as so many others too. But it has something very different. it does not need reciprocity correction for up to 120 seconds and for 120-1000 seconds it only needs 1/2 stop of additional exposure applied. That can be good or bad. If you're after really long exposures (30min - 60 min) it can be hard to achieve. But if your after 60 or 120 second exposures it is nice not to carry around a reciprocity chart.
320TXP is a new version of TXP from when you last shot film. A cool thing with that is you get pretty good results shooting it at EI6400 developed in Acufine's ACU-1 developer. In fact that is the highest EI on their chart for the films listed.
I have a 4990 I use for my 4x5 sheet film. It is okay. But not even close to my Nikon Coolscan 9000ED I use on my 120 roll. Scanning is way, way more forgiving than printing your negatives for sure.
So pick a film and developer and stick with it for a while. Film developing takes time to hone in on. Ideally you'd need a densitometer to measure negatives if you really get into it. But with some miles under your belt you can tweak your times and tune in pretty good that way. Then venture out and try other things and keep good records of your shots at first so you have some better feedback when looking at the results.
Have fun
tuco is offline
10-21-2009, 11:12 PM   #5
Thanks, Tuco
Useful notes.
I was thinkin' about the Fuji Acros and had downloaded the data sheet. Any personal developer recommendations?
So I guess my Panatomic comment sort'a gave me away, huh?
H2
pacerr is offline
10-22-2009, 05:14 AM   #6
Hey, I didn't even register the Pan-X - - that was my main film back in the 70s, with a half frame Olympus.
When I restarted developing recently, I used T-MAX for the simplicity, and it works well. This is the first roll of 120 (and the second roll, period) I developed in 30 years. Ricoh Diacord, yellow filter, Fuji Acros 100.
This is the same film but developed commercially, also the Diacord
Nesster is offline
10-22-2009, 09:58 AM   #7
Gallery Photos: 6
I have recently tried the Kodak C41 black and white film, and I think it's a really good option, especially if you are scanning the film. C41 negative scans very well.
It's an even better option when you want to take advantage of having the lab do the processing and scanning. I can have a roll of C41 120 film processed, all the shots scanned to 6-megapixel files and burned to a CD for me in an hour, for less than $20. The quality of scan is much better than I get off my flatbed scanner with a transparency adapter, and the flatbed takes hours to get a couple of nice scans.
filmamigo is offline
10-22-2009, 10:00 AM   #8
Gallery Photos: 6
Here's a sample of the Kodak BW400CN.
10-22-2009, 10:26 AM   #9
Gallery Photos: 21
Originally Posted by pacerr View Post
Useful notes.
H2
I've only used three developers with 100 Acros so far, PMK Pyro, Rodinal and Prescysol EF. I'm satisfied with the results of each but still learning Prescysol EF and the jury is out on that.
You mention 125PX. I have seen beautiful work with it and Kodak's xtol developer. If you don't use a one-shot, long shelf life developer, pick one that you can run down to photography store and get. Because no doubt you'll go to develop film one day and you will find yourself with exhausted chemicals or a shot you think will be outstanding and your at the edge of the chemicals life and rather not risk it and you're out of new stock.
tuco is offline
10-22-2009, 10:37 AM   #10
Gallery Photos: 21
Yes, they scan well. But sometimes it doesn't have the real BW tones and look. It could be a function of the processing lab. I find you lose highlights real fast with C-41 monochrome. The example above is really good. But nevertheless it has its own style.
tuco is offline
10-22-2009, 10:59 AM   #11
Steven Schaub - Leader of the Figital Revolution
Really good discussion about film (colour, black and white), scanning, developing for scanning...
The Figital Revolution
yurihuta is offline
B&W Film processing: Chemical Question oinkely Pentax Film SLR Discussion 7 01-15-2009 02:00 AM
Do you scan your film? What do you use? filmamigo Post Processing, Printing, Software, and Darkroom 11 09-03-2008 08:58 PM
How many DPI should I scan film at? BetterSense Post Processing, Printing, Software, and Darkroom 6 08-31-2008 04:43 AM
Questions RE: B&W film processing Rmpjr7 Pentax Film SLR Discussion 25 05-29-2008 09:28 PM
B&W film recommendations wanted NaClH2O Pentax Film SLR Discussion 20 05-03-2007 03:07 PM
