Go Back PentaxForums.com > Pentax Cameras > Pentax Medium Format: 645, 6x7, 645D > Need 645 Wide Angle Lens Hoods
Pentax Medium Format: 645, 6x7, 645D Use this forum to discuss all aspects of the Pentax medium format systems.
11-07-2009, 05:15 PM   #16
77EW WIDE-ANGLE LENS HOOD #970 - Schneider Optics
This is from Schneider Optics' website (parent company of B+W) regarding their screw in metal hood for wide angle lenses with a 77mm filter thread. They list that this can be used on wide-angle lenses with up to 70° image angle. Now is the 70° angle for 35mm format (24x36mm film frame) lenses - and would that specification be different for a medium format wide-angle lenses?
The Pentax 645 A 35mm f/3.5 has an angle of view of 90°, so does that indicate that this B+W lens hood will cause vignetting? Can anyone out there help this physics challenged photographer with this answer?
from BH PHoto Video website for this screw in, metal lens hood:
http://www.bhphotovideo.com/c/produc....html#features
The B+W #920 wide-angle metal lens hood is made of black-anodized aluminum with light-absorbing flat black ribs on the inside and protects against contrast-reducing, uncontrolled, stray light. It is designed for wide-angle (zoom) lenses with angles of view up to 70° wide (approx. 28mm in 35mm format).
- the Pentax 645 A 35mm f/3.5 is equivalent to a 21mm lens in the 35mm format.
Thanks.
Yuri
yurihuta is offline
11-07-2009, 06:59 PM   #17
Gallery Photos: 4
I use a fair number of S&W hoods and step rings: they come in pretty much all shapes and sizes: as a sort of generic brand, they may not always be sold by name on Ebay, but I can name one dealer who has a lot of them. I think they're quite sufficient for a lot of things, (round hard plastic is usually my preference, with metal a close second) and hold up just as well as you may need, to my experience.
What I use with my Mamiya is just one of the big non-foldey rubber Mamiya ones: since it works with both of the lenses I have for it, I actually swap it between them when I change lenses, (cause it's beeeg: also, in my case, the hood wears a step-down ring to the filter size I use, so this keeps it all fairly small. (the Mamiya rides lens-up in a bag, so the hood's size isn't a big issue) You could possibly replicate my scheme with one of those Hama-style three-position hoods, which seem to be nice enough, and conveniently-threaded. )
There's a specific Ebay seller I have gotten a lot of that S&W stuff from, I forget if it's OK to mention someone in particular. But most of his stuff is nice as well as reasonably-priced. The nice thing is he usually has all that stuff in whatever depth and size you may need.
(Oh, and on this: )
"Now is the 70° angle for 35mm format (24x36mm film frame) lenses - and would that specification be different for a medium format wide-angle lenses?"
Nope, angle of view is angle of view. By format and focal length, these will change relatively-speaking, but as long as you know the angle of view of the lens and film size you want to put it on, 70 degrees is seventy degrees.
Ratmagiclady is offline
11-09-2009, 08:55 AM   #18
Originally Posted by PeterAM View Post
I have a rigid, rubber (I think that it's rectangular) Mamiya lens hood for a 45mm 645 lens;the front of the lens is 77mm. This hood slides on, over the outer edge of the lens. Don't know what size your lens is.
Check it out: KEH Camera: Mamiya M645 - Hoods and Shades - 45 F2.8 RUBBER (77) PUSH-ON SHADE
Hi Peter, thanks for the reply. Unfortunately KEH doesn't have a photo of the item available. I'm hoping someone who has tried a hood, and knows it works, will reply.
iCrop is offline
11-09-2009, 09:02 AM   #19
Originally Posted by yurihuta View Post
B+W makes lens hoods in addition to their filters. They make rubber and metal screw in hoods. I am trying to find out if one of their screw in hoods would work with my 645 A 35mm f/3.5 wide angle.
My 645 A 55mm f/2.8 came with a generic, metal screw in lens hoods that works really well. I should have thought of that when I was looking for a hood for my new 645 A 35mm f/3.5
I'll let you know if I find something suitable.
Thanks Yuri. It looks as though we're in the same boat. When I find something that works, I'll post as well. Then others looking for hoods for these lenses will have an easier time.
iCrop is offline
11-09-2009, 09:27 AM   #20
Thanks.
Yuri
Given that 70° is less than the 90° angle of view for the 35/3.5, I'm sure it won't work. And at $47.50 it would be an expensive test.
B&H has a number of hoods for medium format available (Lens Hoods), even for Pentax 645, but none for the wide angles.
Adorama has a better selection of hoods to choose from, but it's still a hit or miss situation. Lens Hoods
iCrop is offline
11-09-2009, 09:31 AM   #21
(Oh, and on this: )
Thanks for that. I'll look for S&W stuff and see what might work.
iCrop is offline
11-09-2009, 10:02 AM   #22
This is a picture of the Mamiya lens hood for the 45mm 645 lens;77mm front. You can see how the back is set up to slide/push on over the outside of the lens.
Mamiya RZ67 Rb67 50mm 65mm m645 45mm push fit lens hood on eBay (end time 10-Nov-09 14:34:56 GMT)
I think that the Mamiya 45mm lens has a 76 degree angle of view.
PeterAM is offline
11-09-2009, 12:58 PM   #23
For my FA 45mm F2.8 I use a 67mm WA rubber screw-in I got years back from Adorama. It is cheap but seems to do the trick for now. Not sure for how long thou since the rubber starts separating from the metal ring.
DigitalSlide is offline
11-09-2009, 03:33 PM   #24
Peter, thanks for that link. That looks like a functional hood, however the 35/3.5, which has the 77mm filter size has a 90° field of view. So, while it may fit physically, it will most likely cause vignetting. I wish this were easier. Thanks for the effort though.
iCrop is offline
11-09-2009, 03:37 PM   #25
Thank you. Yes, deterioration can be a problem with the rubber hoods. This one from Adorama may be a better option (DL2077P Adorama 77mm Wide Angle Digital Lens Hood - Petal Shaped). I may give it a try.
iCrop is offline
11-09-2009, 07:28 PM   #26
just looked up my 'early FA lens manual' and it states the following lens hoods for the FA 45mm f/2.8
Hood Type: PHRBC67mm
and for the FA 75mm f/2.8
Hood Type: RH-A 58mm
I don't have a late enough manual for the 645 A series lenses that includes the 35mm f/3.5... still searching
yurihuta is offline
11-10-2009, 07:12 AM   #27
Originally Posted by rparmar View Post
Arg! Yes, my mistake. Bayonet on FA lenses. And I should know since I have a couple right here!
Robin, you're partly right! Looking at my FA 645 45/2.8, it has no bayonet mount for the hood. The original hood must be screw a mount. Sorry about the confusion.
iCrop is offline
11-10-2009, 01:31 PM   #28
Yes, I've found the same info. The those hoods can be found on occasion at KEH. Unfortunately, they're both rubber, which have a tendency to warp and look ugly (not that I'm any great judge of beauty).
So, I guess I'll have to decide between the stuff on Adorama and ebay. I'm leaning toward one big enough for the 35 and a set of step-down rings to fit the other 2. Then I won't have so much to carry around.
iCrop is offline
11-10-2009, 05:54 PM   #29
Gallery Photos: 4
I wonder if anything made for Bronica might happen to fit: they seem to have liked to make square, rigid ones. I forget how they may have attached. Possibly they would clip inside the filter threads.
11-11-2009, 09:14 AM   #30
Yes, I had thought about something like that. But, they'd be expensive and may vignette so I won't chance it unless I can find it locally and try it. Thanks.
iCrop is offline
