Viewfinder type Pentaprism, TTL pentaprism with light meter, folding waist level, rigid waist level magnifying hood
Diopter correction No
Exchangeable screen Yes (at service center)
Depth of field preview Yes (on lens)
Image size 55 x 70 mm
Battery 6V alkaline or silver oxide battery
External battery pack Yes, for use in cold temperatures
Size (W x H x D) 177 x 150 x 91 mm (with TTL prism, without lens)
Weight 1290 g, 1810 g with TTL pentaprisom
Comment Accepts leaf shutter lens for flash synchronization to 1/500s. The TTL pentaprism with lightmeter couples to the shutter speed and aperture and provides for manual 'match needle' exposure setting
Accepts leaf shutter lens for flash synchronization to 1/500s. Accessories: 120 and 220 film backs, 70mm film holder
Actually the Pentax 67 camera was little changed from its predecessor, the Asahi Pentax 6x7 MLU. Of course the 67 finder has the Pentax logo instead of Asahi Pentax. The body also shows this change by just showing 67. Internally, it is rumored that the film winder mechanism was beefed up. One difference I've noticed between the two types is that some of the newer 67 bodies have problems metering the outer bay lenses. Also, some 67s will not meter with the extension tube set or Helicoid tube, even when the lens is set to manual. The first version, Honeywell, did much better in both these areas.
