1. Would like an insert designed to take aa batts in grip
Oh yes, forgot about that one. Wouldnt mind having both normal batteries in the grip either, would make it easier to get both out to charge them.
Originally Posted by barondla
7. live view
If they do what I think they might (live view in viewfinder and on back lcd), you will have a perfectly quiet camera option with SDM lenses.
I will never buy a DSLR with an EVF. Well, if it had one then it wouldnt be an SLR would it? Have you used a camera with an EVF? They are horrible and nasty things to look through and every time i do, im always thankful for the normal viewfinder in my SLR.
Live view on the rear LCD? Thats basically going to happen whether i like it or not, so there isnt any point fighting it. But live view in the viewfinder? yuck
I especially like #2 (DA* 135-400 f/4 -- if they release it, I'll buy one so long as it's not too much more expensive than my DA* 50-135 f/2.8).
Will
How does $2500-3500 sound?
It's probably what this 2.0-2.5kg zoom would cost at the very least.
Based on the assumption that 400f4 is roughly equivalent in bulk (and price) to 300f2.8 (look for Tamron 400mmf4 and compare it to any 300 f2.8 to get an idea).
$2500-3500 would be worth the money with SDM, weather sealing and a constant f/4.0 all the way through so long as it maintained the same colour/contrast of the other 2 DA*'s and was sharp enough for excellent detail in feathers/fur. I'd hold off on a new body for a lens like that!
The biggest gap I see in the current lens offerings seem like a no-brainer (yes, I have been accused of not having one myself...) and that is competitively priced lens accessories:
a) Macro tubes
b) teleconverters
Both of these seem to be "basic offerings" from what many feel to be a premier glass company yet are for all intents and purposes absent from the lens inventory. An MSRP of $525.95 for a 1.4x teleconverter isn't very attractive to the historically targetted demographic of Pentax.
- Backup hard drive. Think about that! You would be able to go on vacation and be backing up all of your RAW files on a 120gig hard drive in the grip.
- Focus assist laser. This might be alittle tricky though.[/i]
I have an external drive unit for this which I think is best as many people use more than one camera soit wuld be more universal, if you upgrade the external unit is still usable
I'm not asking for much.......I like the high FPS in the K20D - just would like the flex to use the buffer to the max by allowing the user to set the JPG size combined with a high FPS and accept whatever the tradeoff is in max number of shots or why not give the flex of setting the FPS too with associated tradeoffs. To me - not a hardware limitation just a software/firmware change in the K20D - once the buffer size and max write speed are given.........Sticking with the K100D for the time being. Of course - the same comment could be made for K100D/K10D too. Ken.
A MF focusing mode for live view that gives you 100% zoom on the LCD over the selected af point. (Make it work like the select AF point mode, but pop up the AF points when you hit the keypad and show you which on you're selecting.) That way you can do detailed focus and pop around the entire frame easy.
- Self-adjusting AF: Set a flocal length, auto focus on a suitable contrasty subject. Then in some way notify the camera that focus was missed and focus manually. Save the correction to camera's ROM after repeating 3 times. Keep the correction data per the lens, focal length, and eventually aperture setting.
- Make the AF button not just deactivate AF, but decouple the AF drive, so MF is possible even with lenses without Quick Shift by a single push of the AF button.
If you mean the AF/MF switch, this is exactly how it works now, no?
