09-09-2011, 05:15 AM   #1
Banned
Various adapters for Pentax Q
Google „P„u„‚„u„r„€„t„‰„y„{
http://dc.watch.impress.co.jp/docs/news/20110909_476402.html
"NF-PTX / Q" (for Nikon F), "M42-PTX / Q" (for M42), "LR-PTX / Q" (Leica R), "OM-PTX / Q" (for Olympus OM), "CFD-PTX / Q" (Canon FD), "PK-PTX / Q" (for Pentax K), for "C-PTX / Q "(for C-mount)," D-PTX / Q "(for D-mount).
D mount is for 8mm cine cameras - it seems to me.
http://www.bolexcollector.com/lenses/40wollensak.html
09-09-2011, 06:02 AM   #2
Interesting. That was quick. Although there is nothing on eBay yet
I hope Pentax made the specifications for the Q mount open and available free of any license terms, like Sony has for the E mount.
09-09-2011, 06:13 AM   #3
Yes, very interesting. Wonder, if there will someday be a T2 adapter too?
I figure that the Q with its small sensor and small pixels might be of interest for high resolution lunar and planetary photography - possibly also microscope photography - where the T2 mount remains more or less standard.
09-09-2011, 07:35 AM - 1 Like   #4
Hi,
Yes, D-mount is the most common 8mm ciné mount (15.875mm thread, 12.29mm register distance). Anyone with an interest in acquiring some of these lenses for eventual adaptation to a "Q" would be well advised to start right now; my working assumption is that the usual eBay dealer "suspects" are already scouring the listings, hoping to corner the market. That was their M.O. with respect to high-quality 16mm ciné lenses, when the C-to-m4/3 format adapters started to appear, and I would expect history to repeat itself.
One note of caution, for anyone brave enough to embark on such an enterprise: while the 16mm C-mount is a more-or-less settled, stable standard, things get a little more complicated when you get into the world of 8mm. For example, the excellent Kern lenses fitted to Bolex H8 cameras (8mm format) actually use the physical C-mount thread; but the register distance is shorter than that of the "true" 16mm C-mount format. And there's also the CS-mount format - often encountered in surveillance camera applications - which uses the C-mount thread as well, but with a still shorter register distance.
Since the H8 Kerns are, by all odds, the most desirable of the 8mm-format lenses, it may well be - if the Q system is successful - that some clever entrepreneur will offer Q adapters made specifically for them: C-mount thread but H8 register. CS-mount adapters would be a possibility as well. I can even imagine a single adapter with switchable flanges to suit all three of the C-mount thread systems; there exist adapters for C-mount lenses, for instance, that come with optional flanges for Robot lenses.
One thing's for sure: the early pioneers who decide to venture into this uncharted territory will have some interesting experiences, both good and bad, with respect to things like vignetting, sensor coverage and physical incompatibilities. That was certainly the case with the first users of C-mount lenses on m4/3 bodies - still is, to be perfectly honest.
Cheers,
Jon
PS As for T2 (any T-mount) lenses: if there's an M42 or Nikon adapter, couldn't you simply use a common M42 or Nikon T-adapter for any T-mount lens you wanted to try?
09-09-2011, 07:39 AM   #5
ogl
Banned
QuoteOriginally posted by Stone G. Quote
The most interesting is for C-mount.
09-09-2011, 09:38 AM   #6
What is the crop factor for the Q though? You might turn a 28mm Distagon into a 112mm perspective.
09-09-2011, 09:48 AM   #7
ogl
Banned
QuoteOriginally posted by kenafein Quote
crop-factor 5.6
09-09-2011, 04:13 PM   #8
falconeye's Avatar
QuoteOriginally posted by ogl Quote
Unclear. C is for video and Q needs rather large resolving power...
There may be some good C lenses. May be.
The good thing is that C lenses for 1/2" do exist. But they never needed to resolve better than 3MP. But some may do...
If C mount lenses would be a good match for the Q then I wonder why Pentax didn't launch the Q with a C mount adapter in the first place. Pentax has a large collection of C and CS lenses.
09-09-2011, 09:25 PM   #9
ogl
Banned
m4/3 users use C-mount lenses and results are not bad.
09-10-2011, 01:09 AM   #10
falconeye's Avatar
I've seen this. But m4/3 pixels are much larger than Q's ...
09-10-2011, 05:27 AM   #11
audiobomber's Avatar
Vignetting wouldn't be a problem with C-mount lenses on a Q, whereas it is on the larger 4/3 sensor.
09-10-2011, 06:16 AM   #12
falconeye's Avatar
QuoteOriginally posted by audiobomber Quote
That's the obvious part. I talked about resolution though
But seeing that some of the C mount lenses cost $1000+, good enough C mount lenses should exist.
E.g., the Schneider-Kreuznach 1" (fits µFT) C-mount XN 25mm f/0.95 ($1200 at B&H)
There, I see other interesting stuff: Motorized CCTV zoom from Canon (probably not sharp enough) or 15-600mm zoom from Angenieux for a whooping $46.000.
09-11-2011, 11:52 AM   #13
Zubati Kit's Avatar
heh 84-3360mm... take that Bigma ,... even for 46k, this has to be the longest superzoom ever devised.
09-11-2011, 01:26 PM   #14
Assuming the adapters eventually make their way to the USA, it peaks my interest in the Q a bit. I actually wrote a blog article about it a few days ago stating my interest in seeing a c-mount adapter for the Q. The Q seems like it would be a nice little video camera with those C-mount lenses. Add the telephoto capabilities with a K-mount adapter and the Q seems like a fun experimental camera on paper (before seeing what the results would be like). Does the Q have anything like that new "peeking" feature that's popular for manual focus?
09-13-2011, 01:32 PM   #15
devorama's Avatar
QuoteOriginally posted by sjwaldron Quote
Nope, no focus peaking. Also, I can't find any way to activate the focus magnification other than turning the focus ring of the Q mount lens. This could be limiting when using an adapted lens.
EDIT: I found out the OK button will activate the focus magnification when there is no lens attached.
adapters for pentax, camera, mirrorless, pentax, pentax q, pentax q10, pentax q7, q10, q7
PENTAX 645 Adapters (what is available) carlprad Pentax Medium Format 7 05-28-2011 09:37 AM
Nikon[Ai F] & Canon[FD] to Pentax adapters: a few questions TAP Pentax SLR Lens Discussion 8 10-06-2010 08:23 AM
Pentax K-x and lens adapters Elliot Pentax DSLR Discussion 10 08-24-2010 10:16 PM
Wanted - Acquired: Genuine Pentax M42 to K-Mount Adapters WiseOx Sold Items 2 08-23-2010 01:44 PM
For Sale - Sold: Pentax Off Camera Flash Adapters and Cables mrchris Sold Items 7 03-17-2010 03:10 PM
All times are GMT -7. The time now is 02:28 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
