Go Back PentaxForums.com > Photography > Pentax News and Rumors > K200D first images surfaced
Pentax News and Rumors Discuss rumored Pentax news (that 'upcoming' Pentax full-frame) in this forum; there is also a section for official news.
12-28-2007, 12:10 PM   #16
Is that a flash release on the left? That is a nice little feature.
Kro77 is offline
12-28-2007, 12:46 PM   #17
Gallery Photos: 18
With Grip
Well if this is true, here is a grip photo
I hope it is a mock up because it does not look good and has no grip-material on it
BrendanPK is offline
12-28-2007, 12:50 PM   #18
Look the top LCD...it's clearly photoshopped in the lower side near the prism.
And the right hand grip section seems so different from top and from towards...
@ KRO77: K100d has that flash release button there.
zntgrg is offline
12-28-2007, 12:58 PM   #19
Not so clear to me, have you seen the full size image? The outline of the top-LCD extends on the left side because the body rises above the LCD on that side.
BTW, I must says, Pentax always makes good looking bodies. I know it's the photos that count, but still.
CSpronken is online now
12-28-2007, 01:06 PM   #20
Here's a detail of the top LCD:
blende8 is offline
12-28-2007, 01:16 PM   #21
TDN
Idunno, that bottom view looks like none of the other existing bodies, so that either looks real to me, or very nicely photoshopped...
I would like the fact that the lower model (the K200) also has the ability to attach a grip. That's my main reason for not upgrading to a K100D from my ist DL.
If this were true, I wouldn't have to spend the extra money on the higher end model
Tom
P.S.: thanks for posting these Hope you don't mind I linked to them on a Belgian photo forum.
TDN is offline
12-28-2007, 01:37 PM   #22
I didn't see full-res shots...now i agree, imho this is the real thing: but now it looks quite strange they swapped the card activity LED, the Fn button and the dial...they they reworked half of the main board to do such a thing?
zntgrg is offline
12-28-2007, 01:37 PM   #23
kay
Hmmm, looking at these again. I retract my earlier post!
The only thing that still looks a bit dodgy is the second zero in the K200 inscription. What I thought was obvious signs of photoshopping around the shutter area isn't - in the closeup shot it's clear that they just changed the plastic shape to accomodate the green button. Also, just noticed that the lens in pic #4 above is the DA* 16-50 - I don't remember such a promotional shot of the original K100D/Super.
It seems from the battery door that the camera still uses AA batteries! I wonder if the grip takes extra batteries, or if it's just for convenience? It doesn't seem very big, certainly not big enough for the D-LI50 cells nor another set of AAs. But it's not impossible that it contains a fixed rechargeable cell or maybe at least some place to store SD cards?
Nice find! Dying to see the K20D now
kay is offline
12-28-2007, 01:40 PM   #24
Regarding the 2nd zero, like the top LCD there is a slight body curve, it's an optical illusion.
zntgrg is offline
12-28-2007, 01:44 PM   #25
If you look closely, the contacts for the grip are done the exact same way as the K10D which means to me... weather sealing !
thibs is offline
12-28-2007, 02:22 PM   #26
Gallery Photos: 8
Originally Posted by rvannatta View Post
With an improved 10 mp sensor inside this provides most of the functionality of the K10 in a smaller box.
What? Where are you getting that? Those things you've listed aren't near "most" of the difference between the K100D and K10D.
So, anyway, what's up with dropping the "D"?
mattdm is offline
12-28-2007, 02:27 PM   #27
Well yeah they dropped it ... about an inch.
12-28-2007, 02:29 PM   #28
Originally Posted by LaRee View Post
I don't know what the mf/af and shake reduction buttons look like on the current k100d, but these buttons look to be an improvement on the k10d buttons of the same. I fumble with the small lever type button on the k10d, these look much better!
The rotational switches on K10D are much easier to seal than the slider type switches on these K200D images. Dont expect the K200D to be weathersealed.
/Mats
Mats is offline
12-28-2007, 02:31 PM   #29
Well yes it is: forget the In-body Raw development, the two-wheels controls and use the smaller body of a K100D as base. The rest is probably a K10D in a K100D-style body.
Even the sealing and the grip are there
thibs is offline
12-28-2007, 03:30 PM   #30
this is precisely the way that the K10 is labeled. what isn't on this model posted is the 'sticker' that goes on the bottom of the camera. this is the ONLY place that my k10D says its a K10D.
I suspect that sticker changes depending on which country it is going to.
rvannatta is offline
