Yesterday I was waiting for a White-throated Dipper. While waiting I
played a bit with the AF at the stream. No way I could get the damn
thing to lock except when trying at some rocks. After wards I did the
upgrade.
Today I sat by the same river, with same lens, at exactly same spot.
The light was very similar. When retesting, it focused just as we
should expect it to do. Every time I tried it focused, and it did
pretty fast to. Impressive :-)
okay, that does it. i'm going hunting for birds first thing in the morning, i mean, now that we have proper af, there's no excuse left.. my pentacon 300mm/f4 is waiting anxiously (or should i say weighing it's 3kg or so)
oh, wait..
nanok goes to google for a manual focus firmware upgrade
I'll maybe try it tomorrow, since I'm too tired, now. I don't really challenge my K20's AF much, it seems, but I have a 135 with which I've suspected the SR could be better. I bet I might notice something, if it's there to notice.
I tried both the 50-135 and the 70mm for some just shooting around the room, SR is better with both and it does seem to hunt less in low light, it does hunt less, it sems to not double check it's double check.
add me to the group who thinks af is improved... did my usual pointing around my dimly lit room (single 60 watt flourescent bulb pointed toward a wall) and it was locking quicker in dark areas and in areas w/ little contrast where before these were the types of areas where it would hunt more often. I'm not saying it's locking instantaneously on white walls, but it does seem to be better...
I don't know, Flyer. I wouldn't without finding out for sure it would be OK...
I've just installed the new firmware. AF is *definitely* behaving differently. More decisive, anyway... I hope it's not sacrificing accuracy. Loading up some test shots for a look: my eyesight isn't the best today, (Dry eyes, so everything feels a little off. Yay, pollen count ) I was just getting used to knowing if I was getting a good lock from the AF behavior, so I'm feeling a little less confident there, (till I get used to this, anyway) but I think it's working OK.
And, re: my previously-mentioned tests of my old 135 Takumar Bayonet out there, I boneheadedly forgot to input the focal length, so the SR was set for my 28. Nonetheless, I do think I got better results than I was accustomed to expecting. (Even, I think, with that set properly. This lens is so light for the effective FL that I find the steadiness a bit challenging, and I was *not* very steady today, by my standards. But this is very promising. )
Reason: Additions. :)
I just upgraded, had my DA 35ltd macro on the body and just tried some shots in a *very dim room here... I really wish I had thought to take the time to try some shots before the upgrade so I could compare, but it does seem to hunt just a bit less. Accuracy seems fine.
