How to fix a sticky aperatue ring on the A 50mm F1.7
I found this fix that seems to work, but be careful to not lose any parts. If you put this in your search engine 'pentax aperture ring fix' you may come up with some more info.
"Anthony Armstrong, Dec 17, 2003; 10:14 a.m.
I had exactly the same problem with a Pentax 50mm A f1.7. It is easy to resolve by unscrewing the lens mount and lifting off the aperture ring. (Put lens cap on and place face down on a folded towel first). Watch out for the little spring, tiny L shaped plate and even smaller ball bearing to pop out - you will want to put those back if you want the aperture ring to 'click' at the f-stops. You will probably find the the two little spring 'plates' that act as 'locks' to the "A" button, are both intact but the little plastic ridges they rest on are worn or broken so it is almost impossible to repair to origional functioning. No problem, just throw away one, or both, of the spring plates and reassemble. (I often 'stick' the little ball in place with the tiniest dab of silicon grease to hold it while reassembling). With the springs removed you won't have to press the little button to shift from, or into, the "A" setting on the aperture ring, so it can get accidentally knocked out of the "A" setting more easily. Personally I'm always switching from "A" to a specific aperture about every other shot so I actually prefer the lens without the button lock on "A". It sounds more difficult than it is - good luck.
