Go Back   PentaxForums.com > Pentax Photography > Pentax Photography Knowledge Base
Notice
Account Status Notice
Dear Unregistered: Please remember that questions are not to be posted in the Knowledgebase. Please only post articles or useful resources pertinent to Pentax.
Pentax Photography Knowledge Base Post and view articles with answers to common Pentax-related questions within this resource.
Old 06-04-2008, 06:45 AM   #1
user440's Avatar
Gallery Photos: 4
Sand Damage - K100D
Strange, I can't belive this hasen't been discussed before but I can not seem to find it via search.
I am on vacation at Hilton Head anmd may have caused some sand damage to my camera. When swivel the preview switch forward (on the shutter release) I can feel that sand has intruded under the switch. After playing with it a few times and blowing it out, it now seems to work but I can still tell there is sand under the switch. The shutter button seems to work ok, but noticed a similar but somewhat less problematic symptom from it.
Now the question. Can I use contact cleaner spray to blow out the sand or will I be better using simple compressed air? Should I do either?
Thanks!
__________________
Mike || Pentax 18-55, Pentax 50mm f2, Tokina SD 70-210mm, Soligor MC 80-200, Focal 135mm f2.8, Sigma 28-70 f2.8, Sigma 70-300 APO | St. Louis Group
user440 is offline   Reply With Quote
Old 06-07-2008, 04:13 PM   #2
user440's Avatar
Gallery Photos: 4
So I'm the only dumbass to get sand in a camera, eh?
__________________
Old 06-07-2008, 04:24 PM   #3
I never had that problem before, but I don't think shooting air (at a reasonable pressure level) would hurt it. Contact cleaner could be used to finish the job. If it was inside the camera, it would be a different story...
flyer is offline   Reply With Quote
Old 06-07-2008, 05:14 PM   #4
Location: the Beautiful Okanagan, in British Columbia Canada
I'd try the air first, and then the contact cleaner.
When you get back you may want to contact Pentax and see if they can clean it affordably.
I have a lens full of sand (given to me that way) but I've thankfully never had a camera that way.
__________________
Most of us are Great Teachers, however only a few of us choose to be Great Students!
click here for a collection of some of my photographs
little laker is online now   Reply With Quote
Old 06-08-2008, 10:28 PM   #5
jdg
If you blow air or contact cleaner into the shutter/power button will the sand or contact cleaner fluid make its way inside the camera and cause further damage?
__________________
jdg is offline   Reply With Quote
Old 06-09-2008, 05:13 AM   #6
Clicker's Avatar
Try simple compressed air as a temp relief then ASAP have the Pentax service center thoroughly clean and fine tune the camera because once sand gets in, it travels via the internal fluids, places where compressed air will not be able to clean. it has to be stripped down and cleaned.
I've done sand in the camera with my film gear.
__________________
Clicker is offline   Reply With Quote
Old 06-09-2008, 04:19 PM   #7
sabarrett's Avatar
Gallery Photos: 7
My main concern would be the sand getting in and ground around internally. Not only will it damage the internal components (like sandpaper!), but the sand will break down and float around inside the camera, along with the stuff it ground up. I would send it in. I feel for you!
__________________
Scott Barrett
Pentax A30, K10D, SMC-A 80-200
Sigma 17-70, 24-135
Miida 200mm M42
Sunpak 383 Super
sabarrett is offline   Reply With Quote
Old 06-19-2008, 05:50 AM   #8
georgweb's Avatar
Hey,
I've been searching for an exploded view of the K100D, only found the K10D,
http://dbsi.org/dist/pentax-k10d-par...ed-diagram.tif
Maybe an e-mail to this guy could help as well,
FUJI S602
All success, Georg (the other)
georgweb is offline   Reply With Quote
Old 06-20-2008, 08:18 AM   #9
I would not use contact cleaner in fear that it could damage plastic. A safer bet would be compressed air only.
el gorko is offline   Reply With Quote
