Dear Unregistered: Please remember that questions are not to be posted in the Knowledgebase. Please only post articles or useful resources pertinent to Pentax.
Pentax Photography Knowledge BasePost and view articles with answers to common Pentax-related questions within this resource.
tractman, it can be used on the camera hot shoe but you have to be careful if you buy one of the older units (Vivitar has been making these units for many years) because of the trigger voltage issue. I bought a new one from Adorama so I expect no issues using it on the hotshoe. I'm still waiting for it to show up but I think it's going to be awhile:-(.
__________________
Pentax K10D, some lens and other stuff.
I just found out, I'm a GWC too!
tractman, I use the Vivitar 285HV on my *ist DL and it works great. It says it has a light meter on it, and it does, but it's actually kind of useless. I only use the dial to use Max power, 1/2, 1/4, or 1/16 power.
As for the voltage that Eaglerapids talked about, he is right, but the 285HV is under six volts (safe for DSLR's). The normal 285 or 283's are not safe, as they have very high voltage. For more info on the 285HV and such, visit this Strobist site.
I don't suppose anyone here knows of a Canadian retailer selling the Vivitar 285HV new? I've checked all the major places (Henry's, Vistek, etc.), and only Don's Photo is selling them. They are, unfortunately, asking $180, while the average price in US stores is $90. Does anyone here know of any other Canadian photo retail stores that sell this flash? I would rather avoid the customs trouble of ordering from the US, if at all possible.
Update: Got a used one from Vintage Visuals in Calgary for a decent price. Turns out Vivitar no longer has any distributors for these in Canada. I'm very pleased with the unit and highly recommend it. Mine triggers at 4.5V, just for the record.
Hello,
I have some addition information to add, based on my experience. I recently aquired a NON-HV Vivitar 285 in a deal. It is one of those made in Japan with a serial number of #4812347. The trigger voltage is 7.5 volts measured with my digital volt meter several times with the same result. This is well within the 25-30 volts stated by Pentax tech support. The voltage never goes above 7.5 volts static or during manual operation. I am pretty happy with it as it has good range and quick recovery. So I think anyone that intends to use an older flash should measure it or have it checked by a good technician.
Dave, I've got a Japanese built non-HV 285 with a serial number in the 3.1 million range that also has a low voltage trigger. The manual for the flash was printed in 1978, so if that's anywhere close to when the flash was built then the 285 has been available with a low sync voltage for the last 30 years at least. The early/mid '70s units may have been high voltage sync but if anyone finds a used one it never hurts to check.
For reference my 285 HV built in China around 2006 has a serial number in the 8 million range, so there are huge numbers of the flashes out there.
i've heard many stories about people using vivi285 (not the HV ones) on-camera and it wound up frying the camera.
this is a little off topic, but for the k10d, if i'm using slaves and 2 off camera flashes, can i still only shoot at 1/180?
And often 1/180 may be too fast. Take a couple of test shots at X before you commit to something that you want. You might have to drop to 1/125 or even 1/60 to ensure proper synchronization.
__________________
Albert in the Rockies - Items in bold are in the pic in my profile
SF-1, MZ-S, AF500FTZ
M 100/4 Macro, M 400/5.6, FA 28-80, FA 24-90, A 70-210, A 1.4X-S
K10D, D-BG2 grip, DA 12-24, DA* 16-50, DA* 50-135 Manfrotto 055B tripod with 0168 ball head, Benbo Trekker tripod, Velbon UP-43 Monopod
My Flickr Photos - Pentax tests: http://www.flickr.com/photos/albert_berry/
I have a 283 that I bought in the late seventies and it has 250 volts. So don't assume anything, measure it first with a good meter several times in full manual. It is nice to know that you don't need the HV models, since there are so many non-HV out there.
