nothing wider than 2.8 for zoom (well i think some brand made f2.0 zooms)
I guess if you dont really need the flexibility of changing focal length much, you'd be much happier with a prime, and your wallet would be alot happier too..
Quoted for agreement, the 50-135 is a superb lens and albeit a bit more expensive than the other lenses listed above the optical quality is top notch. As mentioned earlier, you may want to look at investing in a prime rather than a zoom if portraits are your thing and you want solid IQ, fast aperture on a fairly tight budget.
But which would you go for, if you had to choose one lens for sharpness (and color accuracy), if you don't mind being asked a difficult question?
Depends on focal range you want: I would give the nod to either the DA* 50-135 or the Tamron 28-75. I own both and they produce sharp portraits wide open. Based on my copy of the DA* 16-50 I do not recommend...very poor image quality at f2.8 but that may be a problem with back focussing on my copy. The FA 50 and FA 77 limited are also great portrait lenses when mounted on a DSLR, though they are not zooms.
I just reread your initial post in which you stated your required focal range: 30-70mm. In that case, I would highly recommend the Tamron 28-75mm f2.8; it is an awesome lense and does very well at 2.8.
I've been think seriously about the Tamron 28-75, and may buy it, unless I find a lens that alco can be used as an allround lens, which in my case means that it should start at 17-18 mm. The Sigma 17-70 does that, but it doesn't give me 2.8 lens throughout the whole zoom range.
