Originally Posted by Iron Lion
Question...? What would be the difference between a telephoto Macro lens and standard lens of the same focal length when taking say, Surfing shots and closer range macro shots with the same lens? I'm looking for a reasonable priced 70-200 or 300mm range that will do a good job at both.
By standard I assume you mean a non-macro telephoto, rather than an actual (say 35mm) standard lens.
A macro lens allows you to focus at very close distances, providing additional magnification (by virtue of the close focus). The non-macro lens will not focus from as close a distance, preventing you from achieving the same level of magnification.
If you want to do macro work and have the $$$ you should get a macro lens so you can achieve both of your stated goals.
