11-30-2010, 02:56 PM   #1
Vivitar 28mm K mount problem
Hi,
I would like some help from you folks with Vivitar k mount lenses.
Just got this 28mm f2 k mount, but it doesn't mount in my K20D. The problem is this piece in the back around the lens that is to big. I compared with other Vivitar 28mm I got, the Close Focus f2.8 (which is very good). See the pictures for the comparison.
I think it is possible to grind/cut the piece so the lens can mount. The questions are: is this f2 lens good enough to be worth the trouble to made the modification? Is that piece of metal really necessary, what is it there for?
(Sorry the bad grammar)
Thanks for any help and advice.
11-30-2010, 03:21 PM   #2
there are lots of threads on cutting this down to size, or removing it.
there should be several small screws that remove this from the lens mount.
I would remove it then cut it, do not cut or file it while on th elens for risk of scratching the rear element, and also to avoid filling the lens with filings
also note that this lens is prone to sticking aperture blades, due to oil leaking out of the focusing helix grease
12-01-2010, 10:30 PM   #3
I have an M42 version of this lens and even it wont fit well in my k-x + m42 adapter.
Anyway, I grinded that metal part with my Dremel.
The lens is also pretty soft and mine has a lot of oil in the aperture blades and won't stop down past f4.
12-02-2010, 04:09 PM   #4
Here it is after the grindind. It works now. The task wasn't so difficult after all.
There is some oil in the blades in my copy too but they still work fine. The problem now is the focus ring is so hard, but I'm afraid I don't have the skills to fix that.
I have to test the lens to see if it is really whorth it.
vivitar 28mm...unknown mount irishwhite Pentax Beginner's Corner Q&A 4 02-17-2010 10:35 AM
Vivitar 28mm f/2.5: What's the value of having a TX mount over M42? indytax Pentax SLR Lens Discussion 8 08-08-2009 03:18 PM
For Sale - Sold: Vivitar 28mm f2 (Kiron) Lens In K mount - Like New warpedwoof Sold Items 4 05-07-2009 06:01 PM
For Sale - Sold: Vivitar 28mm f/1.9 lens (K-mount) Rykoh Sold Items 5 09-28-2008 07:38 PM
For Sale - Sold: Vivitar 28mm f/2.8 K-Mount superfuzzy Sold Items 0 12-29-2006 07:39 AM
