Go Back PentaxForums.com > Lenses and Accessories > Pentax SLR Lens Discussion > What to pair with DA12-24: Tamron 28-75 or 17-50
01-18-2008, 03:50 AM   #1
Hi,
I have been waiting for Tamron 17-50 since I got my K100D and later K10D. It has been like 1 year. (In the mean time I used sigma 17-70 but I needed faster lens especially for indoors.)
Finally last month I gave up and decided on the DA12-24, Tamron 28-75 combo.
I already got the 12-24.
So, now assuming that 17-50 will be available in a few months time, do you think I should stick to my initial decision (12-24 + 28-75) or change it to (12-24 + 17-50).
I have no problem waiting for a few months since I already have a FA35 and DA70. (I sold sigma 17-70) But if I decide on 28-75, in a few weeks time I am planning to get it.
It was easy decision when 17-50 was not available Now it got more difficult to decide. My concern is if I get the 17-50, 12-24 will be in an idle position since I am relatively lazy in changing lenses.
Thanks.
alib99 is offline
01-18-2008, 05:50 AM   #2
Gallery Photos: 14
Did you check the Sigma 24-70 f2.8? It looks like a nice complement to the DA12-24.
lol101 is online now
01-18-2008, 06:04 AM   #3
Thanks but it is too big and heavy. Otherwise they would be a perfect pair. Maybe 24-60 is smaller but then it does not have a considerable advantage over 17-50 in the long end.
Pentax means small and light right
alib99 is offline
01-18-2008, 06:25 AM   #4
Stick with the 12-24, 28-75 combo. I have the Sigma 10-20mm and Tamron 28-75mm combo for my ultra-wide->short telephoto range. I don't miss the 21-27mm gap, and you'll have even less of a gap with the 12-24mm.
egordon99 is offline
01-18-2008, 07:02 AM   #5
I thought about this for about 6 months and wound up with the same combo. 10-20 and 28-75
My advantage though, is I have a gap filler. the pentax 18-35 that came with my *istD. It also uses the same filters as my 28-75, 67 mm,
the other thing, and maybe this does not apply, I still use my PZ-1 occasionally, hence I took the decision to go only with Full Frame lenses (except for the 10-20)
Lowell Goudge is offline
01-18-2008, 07:52 AM   #6
So far nobody recommended 17-50
I think I do not need to wait for 17-50 to become available.
alib99 is offline
01-18-2008, 07:57 PM   #7
That's my recommendation, too, though I never had the 10-20 or 28-75 :-)
SpecialK is offline
01-18-2008, 08:50 PM   #8
m8o
Gallery Photos: 16
alib99, sounds like you're building my kit. 28-75 f/2.8 was 1st, then 12-24mm f/4 (then 50mm f/1.4, then the Biggerma, then the Voigtlander... that road leads to the poor house... )
My only desire on the wide end is a fast wide angle prime for some wider angle milkyway shots then w/the 50mm f/1.4, should I get away from civilization any time soon again. My kit's pretty much done now. Will probably get a 70-20mm f/2.8 when one ships, or DA* 200m f/2.8 and then finally done. (ya, right) sorry, I digress... That Tamron rules for the money. It's a good choice. I'll echo not thinking I need to fill every focal length.
m8o is offline
01-18-2008, 11:06 PM   #9
mo8, its really interesting
I had the chance for a VL but I chose DFA100. Sometimes I regret but I am not good at MF
Unfortunately I am still not set with the Biggerma. You know, we all have a boss at home As an easy solution I may endup with "just" bigma
I can say, I am surprised that I am using 12-24 as a travel lens (Other lenses I have are FA35 and DA70 and most of the time they stay in the bag in a travel to a new place. ).
Well, you say your kit is pretty much done but apparently you have at least two new lenses in your wishlist
alib99 is offline
01-19-2008, 12:48 AM   #10
axl
Gallery Photos: 36
Maybe consider Sigma 24 - 70 f2.8.
It's a massive lens, but haven't reat bad review yet and you wouldn't double cover, or loose any range...
axl is online now
01-19-2008, 06:31 AM   #11
Gallery Photos: 4
fast wide angle
Have you thought about the Sigma 24mm F1.8? It's one of my fav lenses. Am at work so I don't have access to my images, but it's a pretty darn good performer. Many think it is the best of the "sigma wide and fast crew".
NaCl(a wide and fast fan myself)H2O
NaClH2O is offline
01-19-2008, 09:28 AM   #12
m8o
Gallery Photos: 16
definitely. Thinking of the 24mm more then the their 20mm and 28mm (as the 20mm doesn't 'test as well'). Though their 28mm, and even the Pentax 31mm ltd is a possibility (just so I could have more Pentax glass!). I actually need to experiment with test shots using these two zoom lenses being discussed in the OP at the different focal lengths so I can better understand the resulting FOV produced, and decide on which to get after that. That btw, is a great 'feature' of zooms.
m8o is offline
01-20-2008, 04:55 PM   #13
I will also recommend Pentax DA12-24/4 and Tamron 28-75/2.8 pairing. This is similar to the kit I am building. I have the Tamron 28-75/2.8 but instead of DA12-24, I have got FA20-35/4 and will be getting the Sigma 10-20 towards the end of the year since I have just bought two new lenses recently!
cheers
Kenny
kjao is offline
01-20-2008, 05:18 PM   #14
If you can consider something expensive, how about the FA* 28-70mm?
tux08902 is offline
01-22-2008, 03:06 PM   #15
I have Tokina 19-35 & Tamron 28-75
My configuration in zoom lens raises similar question for pairing. I am going to receive Tamron 28-75 f/2.8 either today or tomorrow. And I have the Tokina 19-35 f/3.5-4.5, which I paid below $100 used and I find it a great performer for me. What is ideal to me is to have both lens working for digitial as well as film boides. So my zoom lens are as follows:
1. Tokina 19-35 f/3.5-4.5 with 77 filter size. I bought it used recently and I have been loving this lens. The manual focus is not that great in this lens due to short focusing path.
2. Tamron 28-75 f/2.8 with 67mm filter size. I should get it today
3. Tamron 70-300mm Di LD Macro. (planned for the long end)
And I am thinking of how to fill in the zoom in the wider end, and DA 12-24 is a wonderful choice but it seems to be on the expensive end to me and I am thinking along the line of Pentax 10-17. I don't know how well the Sigma 12-24 or Sigma 10-20 goes and I assume it is not as good as the DA 12-24. So far I am down to few choices in order of interest for my wider end zoom
1. Pentax DA 10-17 f/3.5-4.5
2. Sigma 10-20 f/4.0-5.6
3. Pentax DA 12-24 f/4.0
4. Sigma 12-24 f/4.5-5.6
Comments, thoughts are welcome as I may not know Pentax DA 10-17 well enough as a lot of people talk about it having focal range not likely used commonly. But I like it because of my unique other lens with Tokina 19-35 f/3.5-4.5.
Thanks,
Hin
hinman is offline
