I have my first "real" wedding coming up in a few months and need to buy a new (or two) lens(es). I know I want an f/2.8, but what do you guys and girls use most in focal lengths? I have been looking at the Tamron 17-50mm, the Sigma 18-50mm, and the Tamron 28-75mm. Just so you know, I have a 50mm f/1.4 now, plus some other lenses that are not suitable for indoor weddings.
What do you think about these or give me your own likes and dislikes about your lenses.
Don't forget the DA* 16-50.
It is a great lens, and around here in the Vancouver area, we have had no QC issues that I have heard of. It is an amazing lens even wide open, and gives beautiful colours. It is also weather sealed, but I don't think that will be of much use for a wedding. Don't forget a longer lens for times that you need that extra bit of reach.
I think you will be very good with the Tamron 28-75 for a wedding. But do not forget the flash, even if the lens is f/2.8. There will be a lot of movement (like all weddings) and a f/2.8 will not be fast enough, believe me...
I have a Sigma EF 530 DG Super, so the flash is covered(except I can't find a diffuser for it). The Da*16-50 is out of my price range right now. My perfect bag would have the DA*16-50 and the DA* 50-135, but I just can't do that right now.
I am starting to think, although I really want it, the 28-75 may just not have the wide angle that I want or need.
I think, that for wedding you need a zoom, that covers the 30 - 70 range. Changing lenses is not an option at event with a lot of things going on...
If you need to go wider than 28, then maybe the Sigma 17-70. It is not fixed f2.8, but with the flash it will be no problem at all.
I think a 17-70mm f/2.8 would be perfect. Any such beast out there? I hate using the flash! I would love to either learn how to use the flash properly, or not use it, which is what I try to do now.
Petnax will put a 17-70 f/4, not f/2.8 on the market soon. I don't think that there is a 17-70 f/2.8 on the market right now.
Flash: if you have a P-TTL flash, then try to use it bounced. Of course you would need a white ceiling for that. The other option is to use a diffuser. Either way, you'll need to adjust the exposure compensation to +1/2 or even +1 EV.
When I photograph family events, I use ma Cobra thyristor flash, bounced up. My diffuser is a white piece of paper attached to the flash with a rubber strap. I just have some problems with the exposure settings, since the flash only works in M mode.
