I recently picked up an MC-Cosmicar 35-70mm macro zoom. It seems to basically be a Pentax A, with some kind of coating. Fifty bucks, rock solid, takes pretty good pictures, though there is some distortion at 35. I don't have any snaps uploaded but this is the lens...
Cosmicar is an industrial brand of Pentac mostly CCTV gear but for awhile they produced Pentax lenses with a different multi coating (not SMC) otherwise the models they made/sold were the same.
"M42 28mm F2.8 Derek Gardner Automatic Lens, and how does it perform? The filter size (62mm) is awfully big for a 28 mm /f.28"
"Just used my new to me M42 Vivitar 28mm f2.8 today, which has a 62mm filter thread. Perhaps it is the brother or cousin of the Derek Gardner lens you mention above. Yes it is big - my equivalent Tokina m42 is 52mm filter size. The Vivitar has a kind of universal mount adaptor on it. Sound familiar? Labelled 'Wide Angle'. No auto/manual aperture switch but a wheel to manually stop down while metering and taking the shot. A bit awkward."
Both are Tokinas, of the first generation of Tokina automatic lenses, @1969-1975 or so.
The "Derek Gardner" is a fixed mount version.
The Vivitar has a T4 interchangable M42 (Pentax screw) mount. The M42 T4 mount has that %$(&% wheel thing. I disabled that wheel on mine, so I have an M42 T4 that is now manual only. Much better on DSLR.
I have the Soligor fixed M42 and T4 versions (both Soligor and Vivitar sold the same Tokinas), and a Sears M42. There are versions with 62mm and 58mm filters.
Yup, Nikkor is definitely an off-brand. No respect on this forum, thats for sure!
So, did you mount this directly on your extension tube or has the lens mount on the Nikkor been modified?
Neither, exactly. It's a Nikkor extension tube that goes with that specific lens (allowing it to get to 1:1), and either the tube or the lens will attach directly to the camera.
Some, if not all, old (Pre-AI) Nikkor lenses attach to the K mount, albeit upside-down (i.e., the markings on the aperture ring are on the bottom).
I haven't tried infinity-focus yet (without the tube, obviously), since I just got this lens yesterday. Shouldn't be a problem, though, as the Nikon register distance is longer than the K-mount distance, so the lens is actually 1mm closer in than usual.
I guess I'll be losing a little on the close-up end, but infinity should be fine.
I was wondering when someone would poist a Nikkor. I would have but my only one is a 43-something or other very strange (but at the time cheap and popular) zoom.
Luis: Thank you for the info on the Vivitar m42. How did you modify that wheel ? - I haven't opened up the lens yet but would appreciate and use the lens more if it were fully manual.
Auto Rikenon 135mm f/2.8 M42 lens, $10. So far I like this lens, sharp enough and really nice bokeh. Shooting with extreme back light brings out the haze, but otherwise it works nicely. There's a built in hood which extends maybe 1/2 inch or so... but it came with a collapsible rubber hood so I use that.
