Go Back   PentaxForums.com > Pentax Photography > Pentax SLR Lens Discussion
Pentax SLR Lens Discussion Comment on or exchange opinions about any Pentax SLR lenses in this section!
Old 07-20-2008, 09:53 AM   #1
pasipasi's Avatar
My Pentax SMC-A 70-210/4 won't focus to infinity, what to do?
Hi
I've tried my 70-210/4 SMC-A lens with my K100D and my film slr Super A and I can't get it to focus to infinity. Is there any way to fix this? Any ideas?
-Pasi
__________________
Bodies: K100D Super, Super Program, Super A, P30T, P3N, SF7, ME Super
Lenses: FA 50mm F1.4, FA 28-70mm F4, A 50mm F1.7, A 28mm F2.8, M 50mm F1.7 x2, M 35mm F2.8, Takumar-M 80-200mm F4.5, A 70-210 F4, Cosina 135mm F2.8, DA 18-55mm F3.5-5.6
My flickr
pasipasi is offline   Reply With Quote
Old 07-20-2008, 03:10 PM   #2
FotoPete's Avatar
The SMC Pentax-A 70-210/4 and similar CPC Phase II variant both have loosening issues with the barrel.
The Push Pull Barrel for the lens is a two piece design. The outer shell that contains the rubber grip is held to the focus group that is part of the focus/zoom. The inner shell or column contains the focal length markers on it. For some reason that seems endemic to this lens with age, the 4 screws+collar that hold the outer shell to the inner column gets loose. One would notice the outer barrel slipping or rotating past the focal length extremes.
To fix these, pull back gently on the bottom end of rubber grip. You'll see a metal stripe running across the bottom and eventually four screws 90 degrees apart. In your case, I assume the previous owner had retightened the screwed but with the outer shell in the wrong position. (I made that mistake a couple times myself.)
Just flip the rubber and loosen slightly, the four screws so that there is noticeable play between the outer barrel and the inner column. Mount the lens onto your camera and using the clouds in the sky as reference, align the outer shell with the infinity mark on the column and then retighten the four screws and you're all set.
__________________
Pete - K200D
You know you got a pretty serious case of LBA when you end up buying the same lens twice...
FotoPete is offline   Reply With Quote
Old 07-20-2008, 03:53 PM   #3
pasipasi's Avatar
Thank you very much! I'll try that asap
__________________
My flickr
Old 07-20-2008, 05:36 PM   #4
FotoPete's Avatar
Ah not a problem. The A70-210/4 is a beautiful lens! I hope you'll be able to service it and get shooting soon!
__________________
Pete - K200D
Old 07-21-2008, 12:33 PM   #5
Good Info, mine needs a little adjusting....also need to work on the Hood. I took a fall on a inbankment at the race track a few years ago, feet went out from under me and I landed on my Super Program w/the MD on it right in my Ribs, and the Lens hood got pressed into the asphalt bank....(I got a few severally bruised ribs from that!) So the Hood has a bit of a bend it...need to find a way to roll it out some. It's a great lens and look forward to playing with in on my new K200D.
Amazing how heavy my old lenses are compared to this modern plastic thing that came with the DSLR...though it is a good lens and the lightness is appreciated, sure doesn't quite have the quality feel of the old Metal & Glass wonders...
__________________
JET
2008 Pentax K200D w/BG3 Battery Grip - Pentax 18-55 Kit lens - 1983 Pentax Super Program w/5fps Motordrive - Pentax SMC KA 70-210 F4 - Vivitar Series 1 28-90 F2.8-4 w/matched doubler - Philips G536G Strobe with Filter Set
JETninja is offline   Reply With Quote
