As promised here, I did a quick comparison between these two lenses. All shots were taken handheld in JPG by K20D, AWB, no post processing except resize. A more scientific test should be done w/ a tripod and better lighting control, and in RAW. So we can't make conclusion about which lens is sharper than the other simply based on this test
Couldn't keep my daughter steady long enough for the test, I had to do it w/ my dad instead. Photos in replies. You can click on each photo to view the original one.
IQ wise I don't see much difference from the testing results. Probably because my eyes aren't well trained ...
I can see sublte difference in background bokeh, 85/1.4 has less harsh edges but still has double lines along edges in the background. Spetacular highlights are more round than 77 bokeh.
I am a little amazed that this subject in your testing images has the same expression in every single shot. That is hard to do!
I'd call this a tie between the two lenses.
Obviously the 85mm will have more of the background thrown OOF but it is really splitting hairs with the 77mm here.
BTW the colour rendition from FA lenses are just hard to beat.
Thanks for the nice test.
Very nice subjective comparison with controlled conditions. It's easy to pick out areas from each picture of what I like from each lens.
While you expect it at F1.4, I was surprised at the subtle differences in bokeh at comparable aperture from 1.8 and above. It's almost as if someone took a water brush in Photoshop and did a quick pass at smudging any of the higher contract edges in the background just in case they stood out too much.
Now if I could only do something about the *size* of the 85mm with its hood...
I think the extra bokeh is from the longer focal length of the 85.
The 85 also looks warmer, but the 77 looks sharper to me until f/4 when they're about the same...
Buy your dad a beer, Frank! I know had I asked my dad to do the same thing he would have obliged but would have sported a nastier facial expression
It's great to see a test like this, even if the lighting isn't as controlled as we might have liked. After scrolling up and down I would say the differences are minimal, and are not differences in quality, but in taste or preference. Reading the comments it's clear that some people lean towards one while others prefer the other.
Personally, I prefer the rendition of the 77 Ltd, as well as its bokeh. This is probably a good thing seeing as I just bought one
I haven't bothered looking at the larger sizes cos I doubt either of them is not sharp enough, so no reason to worry about that.
Bottom line that I get from all this: If money is not an issue and you don't need the extra 2/3 stop of the 85* for low-light shooting, then buy the one whose rendition matches your tastes better. Either one is a winner.
77ltd seems like a very good lens, I've seen a lot of pics from it and never seen anything that showed otherwise. 77 is probably a sweeter spot for portraiture on APS-C than 85 as well.
85 seems like a great lens, don't get to see as much of it, but this test gives a good feel.
Bokeh is softer and more plentiful on 85. Both lenses appear sharp, though the 85 appears so right from 1.4, thats the selling point on the 85s for me. While lots of lenses these days are sharp, being sharp with great bokeh too elevates things and 1.4 certainly helps out the bokeh, among other things.
One can get most of the way to a goal with a fraction of the cost. To go all the way, costs a lot more - the choice is there.
