Go Back PentaxForums.com > Lenses and Accessories > Pentax SLR Lens Discussion > Sigma 18-50mm f2.8 EX Macro vs Tamron 17-50mm f2.8 - Brick Wall test
12-13-2008, 07:25 AM   #1
Yesterday I received my Tamron SP AF17-50mm F/2.8 XR LD lens (far right) so decided to compare it to my Sigma 18-50mm f/2.8 EX DC Macro lens (middle).
It's first time doing comparison photos for lens like this. I decided to do a brick wall test first with Aperture priority mode and tried to maintain an exposure compensation value between +1.0-1.3 EV for both lens to match similar histogram curve.
All photos taken at ISO 125 and RAW DNG files imported into Lightroom 2 and resized without sharpening to 800 pixel width @85% JPEG Quality. Noticed the Sigma @50mm seems a bit wider than Tamron @50mm even though the distance/tripod setup remained the same ?
Updated: Part 2 with 100% crops posted here.
  1. Sigma @18mm 1/160 sec at f / 2.8
  2. Sigma @18mm 1/100 sec at f / 4.0
  3. Sigma @18mm 1/25 sec at f / 8.0
  4. Sigma @18mm 1/10 sec at f / 11
  5. Sigma @18mm 1/6 sec at f / 14
  6. Sigma @50mm 1/125 sec at f / 2.8
  7. Sigma @50mm 1/60 sec at f / 4.0
  8. Sigma @50mm 1/15 sec at f / 8.0
  9. Sigma @50mm 1/6 sec at f / 11
  10. Sigma @50mm 1/4 sec at f / 14
  1. Tamron @17mm 1/80 sec at f / 2.8
  2. Tamron @17mm 1/30 sec at f / 4.0
  3. Tamron @17mm 1/8 sec at f / 8.0
  4. Tamron @17mm 1/3 sec at f / 11
  5. Tamron @17mm 1/2 sec at f / 14
  6. Tamron @50mm 1/60 sec at f / 2.8
  7. Tamron @50mm 1/30 sec at f / 4.0
  8. Tamron @50mm 1/8 sec at f / 8.0
  9. Tamron @50mm 1/4 sec at f / 11
  10. Tamron @50mm 1/2 sec at f / 14
eva2000 is offline
12-13-2008, 07:26 AM   #2
vs
vs
vs
vs
vs
vs
eva2000 is offline
12-13-2008, 07:26 AM   #3
vs
vs
vs
vs
vs
vs
eva2000 is offline
12-13-2008, 11:00 AM   #4
I've got the Sigma and it looks like a winner here. Thanks for the walls.
joelovotti is offline
12-13-2008, 11:30 AM   #5
Would you mind posting a non-brickwall photo without compensation? I'm interested in colour and contrast under the same conditions. If it's not too much trouble.
audiobomber is offline
12-13-2008, 12:50 PM   #6
Gallery Photos: 8
Nice setup, interesting comparison.
I would be happy to read your comments also. Not only on the optical performance, but also on handling... Thanks in advance.
bc_the_path is offline
12-13-2008, 02:39 PM   #7
Marketplace Reseller
These are all 100% crops I assume? Otherwise you're only testing for distortion which is moot since you use different focal lengths..
wallyb is offline
12-13-2008, 04:28 PM   #8
They seem like they have too much distortion to be 100% crops. I wrote an online tool here that helps to compare crops from different lenses. It would be interesting to see 100% crops from the images. I'm surprised the Tamron looks less sharp than the Sigma when they're downsized so much.
walter is offline
12-13-2008, 09:53 PM   #9
Sigma - better?
Seems like Sigma did a better job. Is it because of macro mode? I do not own either of the two. So, no personal experience / bias here.
kibipod is offline
12-13-2008, 10:00 PM   #10
thanks
will do a bit later
Handling pretty similar both about same weight - the zoom ring on tamron is noticeably tighter to turn than on sigma.
When i got the tamron and did a quick test indoors in very low light conditions and seemed by sigma handled low light better than tamron. When i did brick test i was surprised how much i had to reduce shutter speed compared to sigma lens to get the same exposure. Could of been slight cloudier outdoors when it came to tamron test though.
Nah resized as i couldn't figure out how to do exact dimensional/area sized crops across several photos (still a noob when it comes to Adobe CS3/Lightroom3) lol
I'll check out your online tool - appreciate it if folks also showed me how i can get crops of multiple images at the exact same dimensions/area etc
Yeah probably the case there. Will do some non-macros later
eva2000 is offline
12-13-2008, 11:47 PM   #11
eva2000 is offline
