Go Back PentaxForums.com > Lenses and Accessories > Pentax SLR Lens Discussion > shy Tamron SP AF70-200mm F/2.8 Di LD (IF) Macro
02-03-2009, 08:05 AM   #1
My new Tamron SP AF70-200mm F/2.8 Di LD (IF) on my K10 is too shy to show up a name in the EXIF. Is it normal for this lens?
gkopeliadis is offline
02-03-2009, 03:13 PM   #2
Gallery Photos: 18
Depends on what tool you're using to read the EXIF; the EXIF data structure contains numeric codes rather than a names. The EXIF reader has to look up the lens name from a table.
Pentax Tags
To get the name right your lens has to send a unique code (sometimes third-party manufacturers use the same code for different lenses or re-use the code for a Pentax lens) and the tool has to have the correct entry in its lens name table.
troyz is offline
02-03-2009, 03:26 PM   #3
Gallery Photos: 5
it shows up when using the k20d, on my unit.
ivoire is offline
02-03-2009, 04:15 PM   #4
Gallery Photos: 4
Pentax Tags
Troy is correct. Sometimes processing the file through a product like Adobe Lightroom will result in translation of the code to a lens model with that data added to the exif, though the name assignment is not always accurate. For example: my Sigma 50/2.8 EX DG Macro is tagged as a Pentax 50/2.8 Macro (would be that it were true ) by Lightroom because Sigma uses the id code for the Pentax lens.
stevebrot is offline
02-04-2009, 02:12 AM   #5
I use Lightroom v1.4 allright. Any workaround? I use my photographs sorted by lens many times ...
02-04-2009, 05:51 AM   #6
Same Here
I use LR 1.4 and just discovered the same thing downloading photos taken with the K20D and Tamron 70-200. I remember trialing a Sigma 100-300 that LR mis-labeled as a Sigma 70-200, but this Tamron gets no identifier at all!
There must be a way to create a lens identifier in LightRoom. Haven't had time to study through it yet, but I picked up an excellent reference manual on LightRoom, "The Adobe PHOTOSHOP LIGHTROOM 2 Book", by Martin Evening. Although it's for LR 2 at least 90% of the information still applies to LR 1.4. Hopefully I'll have an answer for you within the next couple days.
Paul
NeverSatisfied is offline
02-04-2009, 05:58 AM   #7
Paul
Still in Europe Adobe wants 125€ to upgrade from Lightroom 1.4 to 2
02-04-2009, 08:48 AM   #8
While I don't have Lightroom, I've run across similar problems with my Tamron 17-50. My DAM software showed the lens as the code only rather than a name.
I couldn't program the code to name into the software, but I was able to use EXIFTools to write the EXIF Name to the appropriate files, although it was a bit of work. Fortunately, it was the only lens I was having the problem with, so all I had to do was take all the photos without lens info and run them at once.
Aside from that, the program I had problems with updated its lens database once I let it know the issue.
emalvick is offline
Gorgeous Tamron SP AF70-200mm F/2.8 Di LD(IF)Macro jackbullet Pentax SLR Lens Discussion 40 08-10-2009 07:16 PM
My brand new TAMRON AF70-200mm F/2.8 Di LD (IF) Macro gkopeliadis Pentax SLR Lens Discussion 4 02-23-2009 01:39 AM
[EXPIRED] FS: Tamron AF70-300mm F/4-5.6 Di LD MACRO 1:2 Fl_Gulfer Expired Listings 3 12-03-2007 03:18 PM
[SOLD] TAMRON AF70-300mm F/4-5.6 Di LD Macro 1:2 barbosas Sold Items 1 09-02-2007 02:04 PM
2008(ish) SP AF70-200mm F/2.8 Di LD [IF] MACRO Model A001 daacon Pentax SLR Lens Discussion 0 08-20-2007 07:53 AM
