Originally Posted by knochelbiter
Couldn't ask for better timing for this thread. I've only had a couple chances to use the Tele-Takumar 400/5.6 I bought last year, and I had my first run-in with the dreaded purple fringe on Sunday...
I was limited as to stopping-down much (this was handheld from ~30 feet).
This pic is after using LR2 removal @ 100%. Is there anything else I can do? What's the best way to remove this in PSP?
I gave up with purple fringe removal in PSP. (I have PSP X2) as I noted above use the chromaric aboration removal tool which allows you to select the color you want and the radius of correction. Look at what I did with the black bird for example. That was on the JPEG just copied out of the post.
THe advantages other than working on colors other than purple, is that you can enter multiple colors to work on, within the tool. it can do them all at once, but be careful about radius size, as it can leave the picture artificial. My approach is to leave the Dark CA in the picture as they don;t show in prints, but go after the red and green in the whites if they are too bad around the subject, but forget about background. all out of focus will have CA
