Go Back PentaxForums.com > Lenses and Accessories > Pentax SLR Lens Discussion > get autofocus capability for your manual lenses!
04-26-2009, 01:48 PM   #1
Some ebay sellers (of Pentax SMC F 1.7X AF Adapter) declare that:
When mounted between an autofocus body and either a Pentax A type or M type lens, the adapter converts the lens into an autofocus lens.
The focusing mechanism is fast and snappy. no problem with Pentax SMC A 50mm f1.7 lens & Pentax SMC A 28mm f2.8 lens,
Is it possible? Anybody test it?
Adnan EROL is offline
04-26-2009, 02:02 PM   #2
There are a bunch of people on here that report that it will get you close to focus but you will need to manually lock it in.
MrApollinax is offline
04-26-2009, 02:04 PM   #3
Yes, this is true. There's a thread discussing this somewhere not so long ago...
Andi Lo is online now
04-26-2009, 02:05 PM   #4
Gallery Photos: 60
I own one, and yes, it's true ... sort of. With a long lens, you have to manually focus somewhere near, then the converter will fine tune the focus for you. It even works in good light and high contrast with my M 400mm f/5.6. Anything less and it just hunts and gives up. As it is stated to work only with lenses f/4 and faster, I cannot complain. There is a thread where I posted my results on a wintry day.
I was bored. m400 + af1.7X
Canada_Rockies is offline
04-26-2009, 03:28 PM   #5
Gallery Photos: 11
Page not found...
fs999 is offline
04-26-2009, 04:10 PM   #6
Gallery Photos: 60
Originally Posted by fs999 View Post
Page not found...
I see that - I redid the link, but it still does not work. In lenses, look for "I was bored m400 + af1.7" in the threads.
04-28-2009, 07:11 PM   #7
Which ebay seller have this? I never seem to find these TC's when I look.
ballgofar is offline
04-28-2009, 07:19 PM   #8
Gallery Photos: 155
Albert,I took the liberty of fixing your link.
Damn Brit is offline
04-28-2009, 07:22 PM   #9
eBay link
Says he has 10 of them.
G_Money is offline
04-28-2009, 07:51 PM   #10
The SMC-F 1.7x AF TC is an excellent teleconverter. I use it quite a bit on my SMC 300mmF4. Note that while the instructions state it must be used with lenses F2 and faster, it works very well up to F4. F4.5 is reported to work, but I have no experinece at that apature with it. I know F5.6 just does not work except in bright sunlight.
I would be careful about " close focusing claims. while the adaptor clearly will be able to focus closer than your normal 50mm lens, it will only give about a 20% reduction in close focus distance on a 50mm lens, and the longer you go with prime lenses the smaller the reduction in close focus is. that is just optics. It is not meant to replace close upl lenses or extension tubes.
Lowell Goudge is offline
04-28-2009, 10:16 PM   #11
Gallery Photos: 60
Thanks. What had I done wrong?
04-28-2009, 10:19 PM   #12
Gallery Photos: 60
But it will crop the subject by 1.7, which might be what was meant. My next project will be to see how it works with my M 100 macro. It might just give me an edge. A 170mm f/6.8 macro lens, all Pentax glass.
04-29-2009, 03:34 AM   #13
of course it crops by 1.7x after all it is a teleconverter, to my knowledge there is no 1:1 autofocusing adaptor for any camera. It needs to have magnification because im the adaptor changes the mount to focusing plane distance.
as for the SMC-M100 F4, it works just fine, I have one.
04-29-2009, 04:13 AM   #14
I don't understand this... a pure MF lens doesn't have any built-in mechanics for AF, the only way to focus is to turn the focusing ring with your hand. How can a TC make it AF?? Or is it that the TC have some moving optical element used for focusing?
Enlighten me please
simico is offline
04-29-2009, 04:40 AM   #15
Enlighten me please
one more question:
Does it work for instance with a M42 lens?
