Go Back PentaxForums.com > Lenses and Accessories > Pentax SLR Lens Discussion > Tamron Adaptall-2 Mount Question
04-27-2009, 05:19 PM   #1
Location: Forresters Beach, Central Coast, NSW, Australia
I own a Tamron SP 70-210mm F/3.5-4 Model 52A which I currently use on my Spotmatics with an M42 Adaptall-2 mount. It is a fine lens but it lacks a manual/auto lever. The only way it stops down is when the pin on the mount is pushed in.
That means that it is virtually unusable on my K10D (except at maximum aperture).
My question is will it work on the K10D if I buy an Adaptall-2 PK mount? Or must it be a P-KA mount? Are there different PK Adaptall-2 mounts? Will some work and others not work?
Please excuse my ignorance of K-mounts. I jumped from Spotmatics to the K10D and it is my first K-mount.
rayallen is offline
04-27-2009, 06:02 PM   #2
Ray, the Adaptall2 to M42 mount will work with your K10D, but you will need to get a Pentax M42 to K adapter. Please see this link for the modification I did on the Adaptall2 to M42 adapter to keep the pin permanently depressed.
An Adaptall to M42 adapter modification
Good luck.
David
IS050 is online now
04-27-2009, 08:06 PM   #3
F16
Ray, you can use either a 'K mount' or 'K-A mount' adapter, either will work on the DSLRs. With any K mount lens without an 'A' setting, you will have to press a button to 'stop down' meter at the aperture you choose, with an 'A' lens this is not necessary. Nearly all of the K-mount film cameras do not require stop down metering with non-A lenses, Pentax stupidly removed this ability in its DSLRs so any non-A lens requires that extra step in metering. So either K adapter will work, the KA adapter/KA lenses are just more convenient. Without a KA lens you also lose some other features like TTL flash metering.
F16 is offline
04-28-2009, 12:03 AM   #4
Problem Solved
Good luck.
David
David,
Thank you for the link to your neat modification to the M42 Adaptall mount. That is so simple and reversible. I think I might just go with that as it saves having to buy an Adaptall K-mount adapter which I probably would not use very often.
No problem with the Pentax M42 to K adapter - I already have one of those which I use frequently with my range of Takumars.
Problem solved. Thanks again.
rayallen is offline
04-28-2009, 04:44 AM   #5
I have on order a new thing: a M42 to K mount adapter with an inner flange to hold down the pin. About time someone made one. $17 delivered.... I'll report once I have it and try it out. The guy selling them says due to lens varability some lenses won't stop all the way down, i.e. you may only get to f/11 instead of f/22
Nesster is online now
04-28-2009, 03:52 PM   #6
Yes, I agree - about time someone made one. I'll be interested to read your report.
rayallen is offline
04-28-2009, 05:17 PM   #7
F16
The adapter with flange should work fine since it's basically just replicating the action of an M42 body stopping down the lens. One thing to watch out for is that the flange isn't so large that it contacts the rear element or surrounding metal on lenses that have large, protruding rear elements. Main concern will probably be faster wide angle through short telephoto lenses, just be careful when threading the adapter onto the lenses for the first time so it doesn't damage the rear element.
F16 is offline
04-28-2009, 05:37 PM   #8
Gallery Photos: 15
You mean the match dial metering that use to work in my K1000?
res3567 is offline
Adaptall Mount Club (Tamron). pcarfan Pentax SLR Lens Discussion 187 11-22-2009 04:39 PM
For Sale: [SOLD] Tamron Adaptall-2 P-KA Mount maxwell1295 Sold Items 4 09-25-2009 01:21 PM
[EXPIRED] Tamron 80-200mm f2.8 Adaptall includes PKA adaptall mount benjamin59 Expired Listings 7 02-09-2009 05:22 PM
Tamron adaptall mount problem seadog Pentax SLR Lens Discussion 2 05-20-2008 08:54 AM
Wanted: [CLOSED] Tamron P/K-A Adaptall-2 Mount Votesh Expired Listings 0 05-19-2008 09:54 AM
