Go Back PentaxForums.com > Lenses and Accessories > Pentax SLR Lens Discussion > Need Some Help
05-01-2009, 01:21 AM   #1
Need Some Help
My DA*300mm lens will not focus using SDM on my K20D. This is my second copy as I sent the first to Pentax for the same problem and they replaced it with what looks to be a returned lens. Before I send this one back I would like to test it on another body capable of using the SDM motor.
If anybody on the Island of Oahu is willing to help it would be appreciated. I could bring a few of the lens listed in my profile to play with while I test the lens.
PM if available.
Terry
Tyama is online now
05-03-2009, 04:31 PM   #2
Bump
10 char
Tyama is online now
05-03-2009, 04:37 PM   #3
Gallery Photos: 60
Terry, polish up your contacts on both the camera and the lens. Sometimes this helps a lot. I used micro fibre cloth and alcohol on my 50-135 and it is much better so far.
Canada_Rockies is offline
05-03-2009, 05:19 PM   #4
I just tried it but no joy. It's still exhibiting the same symptoms. It will attempt to focus by moving but will never acheive focul lock. Even if I manually focus on a spot and then try to AF it will move out of focus. The other DA 300 axted the same.
My DA 16-50 and 50-135 work just fine. If I'm not able to test the lens on another body I'll send it back next week. Thank you for the advice.
Terry
Tyama is online now
