Originally Posted by Lowell Goudge
I can't answer about origonal adaptall lenses all I have are adaptall 2
I have three - 2's and two "-1's" from way back when . . .
Given that I mainly use Manual-mode anyway, I can't find a significant optical difference in them that I can't attribute to personal technique or modern digital coatings (which rarely appear in real use). I frequently use a P/K rather than a P/KA adapter just because that's the way I work and A/F isn't a factor anyway.
Tamron's Adaptall-2 and most Adaptall (1?) lenses were pretty darn good glass any way you look at 'em -- the technology was refined by then and they were trying hard to produce lenses with optical qualities that overcame the marketing hoopla of A/F in the early '80s. Some compromises were obviously subsequently made in the bodies but the optics weren't degraded so as to keep up market presence and reviews. IMO, they really should be considered along with the (somewhat over-rated?) Vivitar Series 1 glass.
Mechanically and optically speaking, my Tamron Adaptall's are both consistent and satisfactory, given that I know how to work around the Di-issues in the few instances they arise.
I know technology is a factor. If you don't believe that, just try to teach someone to drive an 'old fashioned' manual shift automobile. But once you learn to shift gears (or set aperture/shutter speed) for yourself it's just another machine to get you from here to where you wanna be.
Some old glass, like some new glass is really fine no matter the age if you just take into consideration that the modern amenities aren't critical.
H2
