Not really . I tend to disagree. Pentax can mount a challenge anytime. You have to remember at a FL of 200mm the DoF is very little indeed even for F8.
Bokeh of 200/2 of Canon as shown in your example
Bokeh of 200/2.8 of Pentax ... And this was taken at F3.2
F3.2
And this was taken even at F5.6
Daniel, Toronto
If what you're after is minimum possible DOF, there's medium and large format for you. A film MF setup will cost much less than the Canon 200/2 setup and offer even thinner dof. Heck, even a digital MF setup may cost less if buying used lens and body.
Either way, I'd like to see Pentax develop a DA* 200mm f3.5 macro or re-release the FA 200mm macro before even thinking about a 200mm f2.
I'd like to see the FA200mm macro first too. But those 200/2 photos are amazing. I did chase a 135/1.8 for a while since it seemed like a decent compromise but no luck..
And sorry, Daniel. The 200/2's photos are way better than what you posted. The subjects do an almost 3D "pop" off the background (like some of the stuff you see off the 43Ltd or 77Ltd when something just works right). It's a fairly common effect from a 200/2 (similar for the Canon/Nikon variants) from the images I've seen.
