Go Back PentaxForums.com > Lenses and Accessories > Pentax SLR Lens Discussion > vignette with telephoto, how?
09-08-2009, 08:51 PM   #1
did a search but couldn't really find anything.
looking at few photos i took at the air shot i notice there is a vignette in a lot of them. is that normal even when zoomed in at 250mm? just always assumed most vignetting happens with wide angle.
i've included an untouched image below.
zenimagery is offline
09-08-2009, 10:18 PM   #2
Gallery Photos: 60
One can get vignetting with a telephoto. It is a lens design flaw. My M 400 vignettes on film a bit, but on digital (because the vignetting is outside the sensor) it does not.
Canada_Rockies is offline
09-09-2009, 12:02 AM   #3
Gallery Photos: 15
Using a hood or filter not designed for the lens can also cause vignetting.
Marc Sabatella is online now
09-09-2009, 03:08 AM   #4
try stopping down a step or so and see what happens.
Jason
Jasvox is offline
09-09-2009, 10:52 AM   #5
If it's from the wrong size hood, won't stopping down make it more likely to happen?
Richard
richard64 is offline
09-09-2009, 11:34 AM   #6
Richard
<just nitpicking>
Vignetting either happens or not at a given focal length and aperture combination (likelyhood 0 or 1, at a given definition of vignetting (most lenses vignette somewhat wide open) ). Just sometimes (depending on the scene) human eye doesn't detect it very well.
<end of nitpicking>
To OP: to test vignetting make two shots of nice even blue sky with and without the hood. Preferrably a bit underexposed. Open both files and raise contrast a lot (or even better use levels to stretch the histogram as wide as possible - sometimes also known as equalize ). This should really emphasize any vignetting present. If you treated both files identically then it should be very visible if the hood causes any additional vignetting.
procyon is offline
09-09-2009, 12:09 PM   #7
sorry, I didnt see anything about him using the wrong sized hood.
Jas
Jasvox is offline
09-09-2009, 02:40 PM   #8
Gallery Photos: 15
I speculated that this *could* be a cause, but I have no particular reaosn to assume that is the cause. I'm actually betting on a filter being the issue. Or maybe his fingers got in the frame. Hard to say without an image...
09-11-2009, 10:01 AM   #9
i was using just the standard uv filter that came with the lens (18-250)
note: i've included an untouched image to the original post. should have done so from the start i guess hehe
09-11-2009, 10:07 AM   #10
Gallery Photos: 60
I would try some sky shots with the UV filter removed. It might be as simple as that.
09-11-2009, 10:09 AM   #11
Photozone test says it has 0.83EV vignetting at 250mm f5.6
procyon is offline
09-11-2009, 10:24 AM   #12
i was at 70mm
09-11-2009, 10:38 AM   #13
Gallery Photos: 15
Someone might have *sold* you a UV filter with the lens, but none comes with it. They should have sold you an extra-slim one to reduce the vignetting, but still, some vignetting is still going to happen. You're seeing just one of the many reasons why many of us recommend not using UV filters - they provide minimal protection compared to simply using a hood, and whereas hoods improve IQ, filters are more likely to degrade it.
09-11-2009, 04:39 PM   #14
i was at 70mm
... where it still vignettes 0.8EV
procyon is offline
09-11-2009, 08:29 PM   #15
either i guess it is due to a filter or else it is due to the original hood of the 18-250mm, make sure that the longer edges of the hood are on the top and bottom sides while the shorter edges are on the sides, if this reverses u might experience it...
manumon77 is offline
