I thought I'd look into some cheap manual extension tubes for my K10d and my manual lenses.
Has anyone purchased any from EBay and can recommend a seller or product? I found there are quite a few options out there, and some sound a bit too good to be true. I'll feel a little better if people know a seller or product that they've had a decent experience with.
I got a set from dealextreme.com. I think they were less than 10 bucks and work great. I'd recommend them in a heartbeat. Got them in < 2 weeks.
And do you have any problems with the lens or body attachments? I ask because out of the six review posted there, the lens and or body connection seems to be a concern.
I have the same set VaughnA does, and I would also recommend them.
I thought twice about ordering because of the feedback, too, but I haven't had any significant problems with them.
The tube set comes off the camera body like any other K-mount lens -- push the button on the body, and twist. For removing the lens from the tube, there's a little chrome screw-knob near the end of the tube that you slide away from the lens. It looks like a knob, and it screws into the extension tube, but it's really a slider. That may be where some customers' confusion and trouble comes from. No amount of twisting will get you anywhere.
In any case, it's fine, but I only use it occasionally. I wouldn't call it luxurious by any stretch -- the metal is kinda screechy when you screw the various parts together, and it's thin metal, and the paint inside is glossier than you'd probably want in a perfect world, but for the price it ain't bad.
Thank you and VaughnA for the information. I'm not looking for perfect and at $10, what can one expect. I just want something to play with as I'm not too into macro photography. If I ever get there, I'll just upgrade to a true macro lens, but at least this is a cheap way to experiment.
Quicksand hit it on the head. No problems if you use the little release button for the lens. I put a bit of light grease on the screw threads then wiped it off until a very thin layer was left. They've worked great. I can't see spending any more for something so rarely used.
